Results 1 to 10 of 10
Thread: "Check Oil" Displayed
02-03-2010, 03:50 PM #1Junior Member
- Jul 2008
- Milwaukee, WI
Phantom Black Metallic- 2005 GTO
Hello All,
Having an issue with a "Check Oil" message.... Not sure what to do???.... This is on my 2005 GTO....
Oil level is good... message seems to be intermittent.... Sometimes goes off frequently.... sometimes not at all.... Have been told it is a faulty sensor but need more info.... I know this is not a good message, but am not sure if this means there is a problem with oil pick-up in the oil pan, if sensor is bad, or if there is another problem I am not aware of.... Plz help!
02-03-2010, 06:25 PM #211 years of bangin gears
- Jan 2009
- North Jersey
Your pressure sender is on its way out. Are you getting an actual "CHECK OIL" light? Or are you getting the "SERVICE VEHICLE SOON" light? I know when my oil pressure sender went I got the "SERVICE VEHICLE SOON" light and scanned the car at my job and got a low voltage code. Ordered/replaced the sender and all is peachy.
02-04-2010, 02:06 PM #3Junior Member
- Jul 2008
- Milwaukee, WI
It's actually a "Chech Oil" message in the display.... Also, when searching for parts I'm finding two different types of sensors... on looks like a post that goes into the oil pan (two prong) and the other looks like a plug with a hole on the oil pan side (three prong).... is there a difference (other than the obvious) or will either work?.....
02-04-2010, 06:21 PM #411 years of bangin gears
- Jan 2009
- North Jersey
One might be for a gauge and the other for a light on the dash or level in the pan. Have you scanned the car at all?
02-04-2010, 09:05 PM #5Junior Member
- Jul 2008
- Milwaukee, WI
No... Not yet.... Just got the scanner n haven't had chance yet... will do it tomorrow after work.... friend of mine has an '06 Goat he wants to scan as well...
02-05-2010, 04:32 AM #6Grand Imperial Wizard
- Retired Outlaw Sum Bitch
Have you ever reset your change oil timer thing doohickey? You know the gas pedal three times real fast process?
02-06-2010, 06:27 AM #7Junior Member
- Jul 2008
- Milwaukee, WI
Yes... Actually have done that several times (as the message comes up)...
02-06-2010, 05:02 PM #8
Do you have an oil pressure gauge installed on the car? The reason I ask is if for some reason you replace all the sensors and such and the Check Oil indicator still chimes at you. There may be an issue with the oil pump taking it's sweet time building pressure when you first start the engine.
I had the Check Oil indicator issue drive me nuts for awhile on my '04. I'd check the level. It would be fine. So I ignored it for the longest time. Sometimes I blip the gas pedal right after it fired up and there was no annoying Check Oil indicator. So after I installed the oil pressure/volt gauge kit into the car, I noticed the oil pressure took a long time to come up. So I replaced the oil pump along with many other goodies and that cured the problem for my situation.
Hopefully your issue is a sensor. But if not you know where else to look now.
Good luck!
04 Cosmos Purple M6, SAP Grills & Spoiler, '05 Hood, Procharger, TrickFlow 515 HP H/C Kit, SLP LT Headers/LM II, '05 Big Red Brake upgrade, Drag bags, Holden CV8R wheels, GMM Ripshifter. Tuned by New Era: 515 rwhp/471 ft.lbs. Retuned by J&J Speed: Speed Density tuned 586rwhp/ 492 ft.lbs.
03-08-2010, 03:45 PM #9Junior Member
- Jul 2008
- Milwaukee, WI
Hello All,
Just wanted to say thanks to all for your suggestions on my problem.... I have replaced the "Oil Pressure Sensor" on my car and this solved the problem..... Again, Thanks to all for your help and suggestions.....
03-08-2010, 07:34 PM #1011 years of bangin gears
- Jan 2009
- North Jersey
Glad to hear. Enjoy your car.
So, the Regime Wants a Blank Check to Fight "J.V." Team ISIS
By wileyCoyote in forum Political / Debate ForumReplies: 2Last Post: 12-11-2014, 06:07 AM -
Question: "Check Gages" light flickering on and off
By pdiddyz28 in forum General HelpReplies: 8Last Post: 08-06-2010, 04:06 PM -
Grand Prix GT "check engine light"
By rschap1 in forum Almost Anything GoesReplies: 3Last Post: 10-24-2008, 07:20 PM -
"Check Gauges" light on, how much fuel is left?
By amon37 in forum General HelpReplies: 10Last Post: 01-14-2007, 07:29 PM -
check out nothingface's new song "walking on bodies"
By Ice Spiral in forum Almost Anything GoesReplies: 5Last Post: 07-30-2006, 07:28 PM
