Thread: Security Light
    Renns badboy10's Avatar
    Oct 2009
    Eagle Pass, Austin TX
    2002 Camaro SS
    Exclamation Security Light
    Today morning I turned on my car and the security light stayed on I tried turning the car off and turning it back on but still stayed on anyone have any suggestions wat it might be
    Nov 2009
    NOVA
    2002 C5 - M6 - Blue
    2000 Z28 - A4 - Pewter
    The VATS
    Oct 2009
    2002 Camaro SS
    Newbie here wat are the VATS
    Junior Member SPDYGON's Avatar
    GEORGIA
    RED
    2001 CAMARO ss
    i had that happen to my car , there is a chip in the key and if the key gets wet or dirty it will set the security light . wipe it of and try to start the car . if it does not work your chip on the key may be no good and will need to be replace . my light stay on for about 4 day,s and drain the battery .
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    Here ya go. Read all about it.
    http://www.ls1.com/forums/showthread.php?t=61262
    Member Sas's Avatar
    Loveland/Ft. Collins, CO
    Blue
    2001 Formula Firehawk
    Quote Originally Posted by badboy10 View Post
    Vehicle Anti Theft System
    2002 Arctic White T/A Ws6islife's Avatar
    Sep 2009
    Houston , Texas
    Metallic Pewter
    2002 SLP Firehawk
    yep same problem here just got it fixed today..i did the vats by pass works great..make sure u set ur meter to the right setting if not well its a pain and at the end u feel like this
    Member Leeroyws6's Avatar
    Feb 2010
    fort worth
    2000 trans am ws6 a4
    so whats the right setting?i have a different looking key for my 1998 ws6.its got 2 little brass looking dots on each side instead of an oval chip.i guess i should touch one probe to one side and the other probe to the other side to get my resistance reading...right?
    Junior Member falseprophet79's Avatar
    Mar 2010
    Ogden UT
    RED
    1999 Z28
    just did the by pass... car stranded me 18 miles from home on mothersday! LOL. So 1 towtruck ride and a .20c resistor and were up and running again... eventually I will replace the cylinder and rekey. but for now this will get me to and from wk. I recommend taking a reliable ohm meter with you to radioshack. and checking your resistor values by hand and not just off the package.you might have to use more than one in either series or parallel. depending on the OHM value you need. but this bypass works and it is easy. once you have the parts, it is about a 15min job. THANK YOU TO ALL OF YOU THAT HAVE ADDED YOUR RESEARCH AND KNOWLEDGE. YOU HELPED SAVE ME FROM A FINANCIAL BINDE RIGHT NOW! THANK YOU... Jason.D '99 Z-28 198k miles
  1. security light came on
    By t-rock in forum Stereo and Electronics
    Last Post: 02-01-2008, 04:33 AM
  2. Security Light
    By BlueBomber in forum Computer & Tuning
    Last Post: 01-30-2008, 09:05 AM
  3. security light
    By sk8ters501 in forum General Help
    Last Post: 01-24-2008, 06:10 AM
  4. SECURITY LIGHT ON.. WT* is this..??
    By eleve2003 in forum Stereo and Electronics
    Last Post: 03-04-2006, 01:54 PM
