Results 1 to 20 of 23
01-28-2010, 02:43 PM #1
Header install problem. (back firing)
I just installed long tube pace setter headers without egr hookup and pace setter off road y pipes. I havnt yet took the egr completely off, its only disconected. I sent my computer off to texas speed to get tuned. Its back firing and not running right at all, no horse power, it idles. Im lost in the sause right now and need help. Im guessing its something I installed wrong. Any idea's on where to start?
01-28-2010, 03:05 PM #2
Any codes? Did you break any plugs during the instail? Are all your wires on good and tight and not burned?
Did you use 02 extensions or vette 02s?
J
01-28-2010, 03:29 PM #3
Did you cross up the O2 sensors
Are you sure lol
Bon
01-28-2010, 04:30 PM #4
how is the egr disconnected? Do you have the intake blocked off where the egr goes in?
01-30-2010, 02:35 PM #5
I used the extentions that pace setter sent me. But Im going to soon get the corvette o2s. The EGR was tuned out from my knowledge, I had my computer sent in and re-tuned. I havnt yet taken the ERG off or pluged up the hole on the intake its still "open". I think I must of switched the o2 extention wires up.
01-30-2010, 04:55 PM #6
01-31-2010, 03:32 PM #7
Today I took my o2s off and inspected all the wires, none of them are crossed or burned. I dont recall breaking any of my spark plugs but then again you never know. Im going to try that 1 3/8" freeze plug and see if that works. Has anyone ever heard of this problem before?
01-31-2010, 03:35 PM #8
01-31-2010, 03:38 PM #9
Does it matter that the front o2's used to be on cat and now their just installed on the headers? I took my cats out and installed the y pipe into my flowmaster exsaust.
01-31-2010, 03:51 PM #10
Do you have to take the whole intake manifold off to reach it? thats a tight fit.
01-31-2010, 04:59 PM #11
I'm not sure what you have going on here....the harness for the front O2's drop down off the k-member and the front O2's should go in your header collectors.
your egr connects to the intake just behind the throttle body on top of the intake.......
01-31-2010, 10:26 PM #12
Ok......FIRST THING FIRST: LISTEN TO ORION!!!! That hole in your intake is killing your engine!!!!. HOW it RUNS I have no Idea......Get that hole plugged ASAP and let us know how it goes. DO NOTHING ELSE....DON'T WORRY ABOUT ANYTHING ELSE but that HOLE in your INTAKE.......THEN hit us up with your additional questions/concerns/needs..........
Just trying to look out for you man.....no need to see an LS1 struggle when it doesn't have to!
02-01-2010, 09:30 AM #13
02-03-2010, 05:02 PM #14
My engine does not look like that picture.
02-03-2010, 07:11 PM #15
this is twice this week that I've done this.....I notice now that you have an 01 so you don't have an EGR. You have the LS6 intake which doesn't have the egr port in it like the picture. Now we have to figure out what hole is open. There should be no open holes on the intake. Can you describe exactly where it's at or can you take pictures and post them?
02-04-2010, 10:13 AM #16
02-04-2010, 11:40 AM #17
02-07-2010, 07:37 PM #18
Changed the spark plugs today and it runs perfect lol. Must of broke one while putting the headers on. And I took the whole EGR off also. But the the check engine light is still on. Any ideas?
02-07-2010, 08:25 PM #19
Yea NO CATS.
got get the rear O2's tuned out. then the CEL will not come back but it is not going to hurt anything. Take the car and get it scanned to make sure that this is the only code. then save up for a tune and have it tunned out.
02-09-2010, 12:39 PM #20
SLP Header Install Problem
By 00Z28DC in forum External EngineReplies: 3Last Post: 03-29-2010, 08:23 AM -
Help: Header install problem!
By Josh81990 in forum External EngineReplies: 16Last Post: 02-04-2010, 11:40 AM -
problem after header install
By phantazn in forum External EngineReplies: 7Last Post: 11-06-2007, 04:53 PM -
By rocksws6 in forum External EngineReplies: 10Last Post: 06-11-2007, 12:49 PM -
Big problem after header install.
By yellowv in forum External EngineReplies: 5Last Post: 04-01-2007, 02:32 PM
