Results 1 to 11 of 11
    Junior Member rocksws6's Avatar
    North Carolina
    2001 Pontiac T/A WS-6
    problem after header install
    Well I installed my long tube headers today and after getting everything buttoned back up I take it for a little drive and its sputtering and back firing. Check the code and it says multiple cylinder misfire so I figure its the wires cause they were a big pain in the arse to get off so I got a little ruf with them. Change the wires and its still missing, its not as bad but still popping. I was wondering if its the plugs, I had to pull a few of them out to get the headers in so maybe that's it? They were denso's I'm not sure if that's what came stock? Has anybody else had this problem? Is there something I'm missing? I disconnected the back o2 sensors but that shouldn't what's causing it right? Would the front o2 sensor being bad cause this? I don't know what to do, somebody please help!!
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Check the wires again. They probably aren't seated all the way.
    The coil pack side of the wire should snap onto the coil pack with 2 clicks, in sequence. As you push it on you'll hear the first click. Then push it further on to hear the second click. That means they are fully seated.
    In the spark plug side, the wires should go on with one firm click. If you push it on and don't hear/feel the click, pull it off and try again, because chances are its not all the way on.
    And to answer your question, the rear O2 sensors will not cause a misfire, or any other engine related issues. They are there to tell the ECU that the cat is working correctly, nothing more.
    did you take the coil packs off and maybe put them back on wrong although I don't think it'll even run if you do that? Also, if you left the plugs in you may have cracked the ceramic on them if you banged them with the headers very much. Just a couple of things to check. Check all the wiring around the headers and make sure you didn't burn one on the headers.
    North Carolina
    Thanks guys. I'm about to go and go over it all one more time.
    Supercharged Ricer
    Feb 2007
    San Diego
    2005 Supercharged Tiburon
    Quote Originally Posted by rocksws6 View Post
    How did this turn out? Are you still having problems?
    North Carolina
    Quote Originally Posted by Z28venom View Post
    I got it fixed. It was either a plug or I didn't have a plug wire on all the way. All I know is that changing the plugs and wires after installing LT's is a real PITA.
    Junior Member 01CamaroZ28's Avatar
    Virginia Beach, VA
    2001 Camaro Z28 M6
    That's why I replaced mine when i was doing the header install.
    Supercharged Ricer
    Feb 2007
    San Diego
    It's a lot easier to change them with headers than it is with the stock manifolds.
    North Carolina
    Quote Originally Posted by 01CamaroZ28 View Post
    That's what I wanted to do but my old man was helping me put them on and he talked me out of it.
    "That's just a waste of money if they're still working."
    I wish I wouldn't have listened to him.
    Virginia Beach, VA
    2001 Camaro Z28 M6
    well it shouldnt be too hard to change them out. Like Z28venom said its harder to change em with the stock manifolds on.
    Commerce Ga
    Black, Blue
    07 TBSS, 07 GSXR1000
    Glad it all worked out for you.
  1. SHorty Header Install Problem.....
    By jfl330 in forum External Engine
    Last Post: 07-13-2014, 05:48 PM
  2. SLP Header Install Problem
    By 00Z28DC in forum External Engine
    Last Post: 03-29-2010, 08:23 AM
  3. Help: Header install problem!
    By Josh81990 in forum External Engine
    Last Post: 02-04-2010, 11:40 AM
  4. problem after header install
    By phantazn in forum External Engine
    Last Post: 11-06-2007, 04:53 PM
  5. Big problem after header install.
    By yellowv in forum External Engine
    Last Post: 04-01-2007, 02:32 PM
