01-24-2010, 12:51 PM #1Senior Member
- May 2009
- Toronto
SOM- 2002 SS
Possible to add spacer to front Struts to raise ??
Just curious if anyone knows of any products designed to raise the front coils a bit. I have the eibach sportline springs and while I think the car looks sexy for the winter I'd like to raise it a little bit.
I found metal coil spacers made for the rear in 1/2 inch and I would want a 1/4 inch or so spacer for the front. I want to take apart the strut assembly and slip it inside and put it back together. Not sure if it works that easy so I'm hoping someone can chime in.
01-25-2010, 07:57 AM #2Junior Member
- Jun 2007
- A, A
- 1998 Camaro Z/28
it seems much easier to just swap the springs to ones wit a lower front drop. but as for wut youre asking, idt there is a such thing made
01-25-2010, 01:58 PM #3Senior Member
- Feb 2006
- Orange County, NY
They have them on ebay. People use them to raise their cars to fit 20"+ wheels on the car.
01-26-2010, 05:10 AM #4Senior Member
- May 2009
- Toronto
SOM- 2002 SS
Well I figured if I could theoretically lengthen the spring in the strut it would help the strut do its job a little better. I'm just going to unbolt the bottm shock mount from the lower control arm and throw in some spacers. Adjustable ride height cheaper and less time consuming than coil overs. win-win ?
01-27-2010, 04:36 PM #5Member
- Jul 2008
- new jersey
navy blue metallic- 2000 trans am
BMR sells the spacers that go between the shock and the a-arm.
i would just ditch the sportlines though. i like performance more than looks. what kind of shocks are you on? there's a few coilover kits out there that would let you go just as low but at least have a decent spring rate in the front at least
01-27-2010, 06:59 PM #6
01-28-2010, 07:05 PM #7Senior Member
- May 2009
- Toronto
SOM- 2002 SS
Exactly the plan. Just want to make sure i have ground clearance for when it snows a bit more.
So on the fence to just buy stranos and konis. Money isnt an issue its just wether or not I want to invest any more into this car or just order an 11 5L
01-28-2010, 07:36 PM #8Member
- Jul 2008
- new jersey
koni's/stranos!!!
01-28-2010, 08:12 PM #9
IMO, take it in and have the "Toe" checked, and adjusted if needed after raising it up.
How difficult are front shocks/struts?
By Whitefish in forum Suspension and HandlingReplies: 7Last Post: 04-14-2013, 12:09 PM -
Wanted: WTB front shocks/struts
By Blackbird WS6 in forum Parts Wanted / TradeReplies: 3Last Post: 06-28-2011, 08:15 PM -
Front Struts
By OnEbAdReDSS in forum DrivetrainReplies: 2Last Post: 05-11-2008, 08:30 PM -
AGX Adj. KYB front struts for CHEAP!
By blackSS01 in forum Parts For Sale / TradeReplies: 4Last Post: 12-12-2007, 10:45 AM -
QA1 12 way adj. front struts for 93-02 F body
By greatwhitess in forum Parts For Sale / TradeReplies: 3Last Post: 07-15-2007, 07:46 PM
