Thread: steam pipe
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    steam pipe
    Do I need the steam pipe on the back of the lt1 heads or can I just put plugs in an eliminate it?
    That guy thearborbarber's Avatar
    SoDak
    White over Red
    1991 Suburban
    You need to keep it. LT1's have reverse flow cooling.
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    What dose it have to do with reverse cooling? The cooling reverse happens in the block and heads.
    SoDak
    White over Red
    1991 Suburban
    Scroll down about a third of the way.
    http://www.indipalass.com/ARCHIVE/Te...lingSystem.htm
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    ok thanks. So because there is no cooling passages in the intake, steam or hot spots have to be bled back into the cooling system insted of out the thermo housing on the intake. Thanks for the help.
    SoDak
    White over Red
    1991 Suburban
    Bingo.
    GM Powertrain really had a winner when they came up with the LT1.
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    lol yup This will be my last lt1 build. If it blows up I am going to blow the car up. lol
  1. help with steam line
    By robznob11 in forum External Engine
    Last Post: 05-17-2010, 05:29 PM
  2. I need to let off STEAM!!
    By Blue_01_Z28 in forum Almost Anything Goes
    Last Post: 03-16-2010, 03:17 AM
  3. Question: Anyone Use Steam Cleaners?
    By JoshieDoom in forum General Help
    Last Post: 02-23-2008, 03:34 PM
  4. Steam
    By Waveridr85 in forum General Help
    Last Post: 10-13-2006, 12:17 PM
  5. Steam tubes
    By phoenix1987 in forum Internal Engine
    Last Post: 09-10-2006, 07:41 PM
