Thread: Steam tubes
09-06-2006, 08:25 AM #1Junior Member
- May 2006
- Minnesota
Red- 1987 Trans Am
Steam tubes
Is their a way to eliminate the steam tubes on a LS1? I see that TPIS sells block of plates for the rear, but what about the front? Dosent the front tubes go to the throttle body? If so, should I find a way to block the fronts off if I disconect the throttle body coolent hose?
I do plan on a Ls6 intake in the future.
09-07-2006, 10:52 AM #2
you have to have the coolant line crossover. it's there to remove air pockets that would otherwise collect in those areas. the rear block offs are for the LS6 intake. but, with some minor clearancing underneath the LS6 intake, you can keep the LS1 lines.
09-09-2006, 01:55 AM #3
09-10-2006, 07:41 PM #4Member
- Sep 2006
- Rochester Hills Michigan
Ruby Red- 98 Camaro Z28 402 stroker
402 C.I. Engine:Magic Stick V.4 Cam,LPA Custom Ported Polished Heads,Custom Ported and Polished Throttle Body,Spec 13 Lbs. Flywheel, Centerforce Dual Friction Clutch System,Pro 5.0 Tower, 4.10s
Question: ls1 steam tubes??
By darenw in forum Classic MuscleReplies: 8Last Post: 09-18-2010, 01:31 PM -
help with steam line
By robznob11 in forum External EngineReplies: 0Last Post: 05-17-2010, 05:29 PM -
TFS steam holes?
By garygnu65 in forum Internal EngineReplies: 11Last Post: 03-21-2010, 06:47 AM -
I need to let off STEAM!!
By Blue_01_Z28 in forum Almost Anything GoesReplies: 38Last Post: 03-16-2010, 03:17 AM -
Steam
By Waveridr85 in forum General HelpReplies: 6Last Post: 10-13-2006, 12:17 PM
