    TX
    1999 TA
    Do I need a computer tune?
    Have a 99 T/A with full bolt on, minus long tubes headers.
    I 'am about to put long tubes on and I was needing to know if I will have to tune.
    Thanks Gearheadbob
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    do you HAVE to tune, no. should you, yes. i ran around for a while with stock tune and most bolt ons.
    Dec 2002
    n/w chicago
    2000 nhra edition formula
    agreed with above.
    a few bolt ons, 379 rwhp
    11.96 @113.25
    Member Capster78's Avatar
    Newport News Va
    1998 WS6 M6
    I really dont see a need to tune your car untill you get a Cam. The computer usually will adjust for boltons. You will pull out a few extra ponies but is that really worth the cost of dyno tuning.. Not in my opinion.
    Tech Junkie hammertime's Avatar
    Belleville, IL
    Pewter Metallic
    Quote Originally Posted by Capster78
    Good point. If you plan to get a cam, or heads and cam, down the road, you will definitely need to tune then. If headers is the last mod you want to do for a while, you will get some modest gains from a tune, but as stated it is not mandatory.
    Bombguy99Z28
    Guest
    The computer will adjust for part throttle conditions, the computer will not adjust for wot conditions. You would basically be hoping that the car will run somewhere within the acceptable A/F ratios (12.5-13.5) but the computer ultimately cannot do much about that without tuning.
    The more mods you do without tuning, generally the more horsepower you leave unusable. You wouldn't neccessarily need a dyno tune, but having a friend or something make sure you are ballpark is a good idea.
    Feb 2006
    NH
    2000 SS
    I agree that a tune is not required...but it is a good thing. Get a MAF tranlator.....its not as effective a as a full dyno tune but you can adjust the MAF signal to get ur car operating at a better A/F ratio if you have a way to monitor your o2 voltage and/or knock retard. I use a scanmaster for that.
    Member keliente's Avatar
    Charlotte, NC
    99 Firebird Formula
    I disagree. Unless you plan on adding a cam like...next week, then get a tune. Adding headers I made 339hp and 342 ft/lbs tq. After a tune, 351hp and 355 ft/lbs tq. I gained almost as much from the tune as I did from the headers alone. I also like knowing that my air fuel ratios & timing is as good as it can be, so that I am not missing out on any power.
    I mean heck the least you can do is a mail order tune, which run around $150. Experienced tuners have seen every bolt-on setup in the book and can get you pretty damn close to what you'd see on a dyno.
    z guy denegrader's Avatar
    Apr 2011
    ca
    1998 camaro z28
    any one out there could any one tell me where the computer is located , the one that controls the coolant fans?????
    id really appreciate it as im trying to trouble shoot cooling system and its imperitive in 100 degree weather that at a minimum the fans will run especially at idle at stop lights traffic jams ect. Knowing the fans don't even come on till after boiling temperature. Just don't want to melt my aluminum engine
    any
    one id appreciate it please
  1. computer tune?
    By Black 98 formula ws6 in forum Computer & Tuning
    Last Post: 05-14-2010, 05:11 AM
  2. computer tune
    By kamahlwolf in forum Computer & Tuning
    Last Post: 04-10-2010, 09:08 PM
  3. computer tune
    By rb agee in forum Computer & Tuning
    Last Post: 12-27-2006, 01:51 PM
  4. Map computer or tune
    By Dayak in forum Computer & Tuning
    Last Post: 06-17-2006, 06:10 AM
  5. Computer Re-Learn / Re-tune
    By ss~zoso~ss in forum General Help
    Last Post: 02-28-2006, 09:01 AM
