Results 1 to 15 of 15
Thread: Computer Re-Learn / Re-tune
02-27-2006, 01:23 PM #1
i've heard something about disconnecting one batt cable and the computer will have to relearn all the mods on the car, i'd like to do this because i've had my car in storage for a couple months now, and im going to put it back on the road soon (march 8th ) yea!!
also would it be a bad idea to do this if i have old gas and fuel stabilizer in the tank? should i just burn off all the old gas and then do this?
02-27-2006, 01:59 PM #2Senior Member
- Jul 2005
- Jacksonville, FL
No need to reset the PCM - I'd just fire it up and go.
02-27-2006, 02:09 PM #3
i know i dont have to do it, but if i wanted to how would i go about it
are you trying to say that it does it constantly like all the time when u drive?98' SS Convertible Camaro-76k-Build # 1471, Cragar SS rims, RK SFC's, MAC Panhard, LSX Tune, Shaner S3,
SLP:short thro,Strut tower brace,fan switch
MTI Power induction kit,40 Series muffler,Pacesetter LT's + ORY,12 CD changer,3800lbs
http://www.cardomain.com/ride/787506/1
02-27-2006, 02:14 PM #4Senior Member
- Jul 2005
- Jacksonville, FL
This method doesn't require any tools, less wait time:
PCM Reset
Turn key on, don't start car
Pull PCM BATT and PCM IGN fuses in engine compartment
Wait 5-10 min
Turn ignition off
Replace fuses
Idle will be grumpy until it relearns.
02-27-2006, 02:50 PM #5
alright i remember doing that when i was trying to get rid of a SES code
02-27-2006, 03:06 PM #6
It won't magically re-tune itself because you disconnect the battery. If you want it to really run better and gain the maximum amount of power from your mods then you need to invest in a real tune.
02-27-2006, 04:23 PM #7
yea i know that but i'm broke as a joke, and i dont have enough mods to make it worth it
02-27-2006, 05:59 PM #8Junior Member
- Feb 2006
- Northern Indiana
Black- 1997 Trans Am ws6
Thanks for posting the reset procedure.
02-27-2006, 06:06 PM #9Junior Member
- Jan 2006
- dayton ohio
Blue- 2002 Subaru WRX
there are certain procedures that can also initiate the fuel trim reset... if you know anyone with a high dollar scanner they can reset the fuel trim learn...on some vehicles with the key on but not running pushin the brakes so many times can activate the computer to relearn its tables..
02-27-2006, 06:07 PM #10Junior Member
- Jan 2006
- dayton ohio
some tuners can include the LS1edit install in the price of the initial tune..
02-27-2006, 06:07 PM #11Junior Member
- Jan 2006
- dayton ohio
hope some of that was helpful..
02-27-2006, 06:42 PM #12Junior Member
- Jan 2006
- arizona
metalic blue- 2000 trans am
can anyone tell me about removing the cats and using o2 sims? good or bad?
02-27-2006, 10:16 PM #13depends what your needs/wants are.........if you remove them you will get more power out of it, but it is illegal.........for starters
Originally Posted by i eat rice
02-27-2006, 10:57 PM #14
I just pull the neg cable...put the key in to the run position for a few seconds to drain any capacitors of energy...take the key out, reconnect cable and wahhlahh...let it idle under a load(a/c on max...defroster..etc) for 5 mintues....drive it like it's not yours for 20 mins...and you're set. You'll know when you actually forced a relearn...the engine will want to die when you first try to start it.
02-28-2006, 09:01 AM #15I have seen good gains from people with no mods, it is always worth it if you can find soneone who is good at it that can do it for around 100
Originally Posted by ss~zoso~ss
computer tune?
By Black 98 formula ws6 in forum Computer & TuningReplies: 6Last Post: 05-14-2010, 05:11 AM -
I want to learn how to tune is this a good book?
By Sweet Chops in forum Computer & TuningReplies: 12Last Post: 12-06-2008, 07:36 AM -
Want to learn to tune myself
By purplehawk95 in forum Computer & TuningReplies: 5Last Post: 03-01-2008, 03:38 PM -
where can I learn how to tune the PCM?
By 1 FMF in forum Computer & TuningReplies: 3Last Post: 03-01-2007, 04:31 PM -
Map computer or tune
By Dayak in forum Computer & TuningReplies: 2Last Post: 06-17-2006, 06:10 AM
