Thread: Abs causing soft brake petal???
01-07-2010, 09:14 PM #1
ive got a 1994 25th anni. trans am with abs brakes. the brakes are really soft!! i talked to a "wise" co-worker (i work in a vehicle maintanance shop in the air force) and he said it could be the abs moduel. fluid in the lines are good no air any thoughts?? what else could it be?? thanks
01-08-2010, 03:33 AM #2
on your abs system there are solenoids that are what pulse your abs, if you havent used abs in a long time those solenoids drain brake fluid and the pedal can be low and soft. get on grass or gravel and do a few abs stops and reload those solenoids with fluid. have you changed your fluid lately?
01-08-2010, 03:55 AM #3
01-08-2010, 06:29 AM #4
what kinda shape are your rear pads in? I've seen worn rear pads that will let the pedal travel increase.
01-08-2010, 07:59 AM #5Junior Member
- Aug 2007
- cos
- 2002 camaro
your stock rubber lines can be worn and you should do a complete fluid change also change your pads. maybe you should just try to bleed them first???
01-08-2010, 04:53 PM #6
01-08-2010, 07:24 PM #7
fluid is good pads are in good shape (75%) brake lines are in great shape. the abs hasnt been used in probibly ever so im going to "stimulate" the abs.
Checking the soft top
By Z ROADSTER in forum ConvertibleReplies: 18Last Post: 06-20-2009, 03:06 AM -
Help: Clutch petal
By Bigck4 in forum DrivetrainReplies: 1Last Post: 01-26-2009, 10:58 AM -
soft clutch pedal
By 99yellowz28 in forum Manual TransmissionReplies: 12Last Post: 01-01-2009, 08:52 PM -
Is it my clutch,petal assembly,or both that is sticking under WOT on NX wet 150 shot?
By Z28er in forum Manual TransmissionReplies: 12Last Post: 09-27-2006, 01:45 AM -
GM Has Gone Soft !
By BOWTIE 3 in forum Almost Anything GoesReplies: 0Last Post: 06-04-2006, 06:08 PM
