    NeW YoRk
    2001 ws6
    underdrive pully
    anyone have a preferance on which underdrive pully to get?
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    This is a quote from Hi-po's sticky...not sure if it helps you or not.
    Under Drive Pulley's -
    ATI -
    SLP - $179.00
    ASP - $214.00 - Crank
    ASP - $24.00 - Alternator
    PowerBond - $200.00
    BBK - $229.00
    SLP, Powerbond, and ATI are all good underdrive pulleys with higher walls to aid in belt alignment. They will all show the same average horsepower gains. They don't so much add any HP, rather they reduce HP loss by spinning the accessories slower. Generally people don't have charging issues. If your having problems throwing belts, the Katech solid belt tensioner is great. My belt began to 'walk' off and after installing the Katech tensioner, I never had a problem again. Its a great piece that looks sharp.
    Katech Solid Belt Tensioner - $135.00
    Consider reading this webpage. Its very basic, but is a good way to remind you of the smaller things. http://books.google.com/books?id=AbJ...angles&f=false
    Cushing, OK
    Blue
    2000 Z28 M6 HT
    My vote goes towards SLP or Powerbond. I have a Powerbond
    25% UDP that I plan to install in the next couple of months.
    The reason I picked it is because of the high belt retainer walls.
    I've heard that ATI makes a quality product, but I have no experience.
    ASP is a little lighter, but it's belt retaining wall aren't as high.
    You should be fine with whatever brand you chose. Just stay
    away from March. There UDP has an odd bolt pattern & you
    can't use a normal tool to remove it.
    San Diego ca
    "Arrest Me Red"
    2001 trans am
    i think the slp is made by powerbond but im not for sure on that. i have the slp on my car and have no issues with it. it looks cool to
    Member joedude02's Avatar
    Goose Creek, SC
    Victory Red
    2002 T/A WS6 A4
    pm sent
    NC
    SOM
    1998 T.A.
    ATI is hands down the best pulley out there but is in the $400 range. There is a reason it is on virtually all pure track cars I have ever seen. It has the ability to dampen the widest frequency range of torsional crankshaft vibration. It is also the lightest available and is rebuildable.
    In the last year or so they came out with a 25% UD. Before that 10% was the only UD offered
    Member cuzimoto's Avatar
    Feb 2008
    Newport Beach
    99 Formula
    I've had ASP for 7 years, tons of track slips never a problem. 5 stars from me.
    Member Blue28's Avatar
    Ca.
    Navy Blue
    1999 Camaro Z28
    You forgot Fluidampr, I would rate it high on that list.
  1. Question: underdrive pully
    By 2000dreambird in forum External Engine
    Last Post: 06-26-2009, 02:52 PM
  2. Underdrive Pully Kit
    By mglangley21 in forum External Engine
    Last Post: 08-08-2008, 07:51 AM
  3. Underdrive Pully kit
    Last Post: 05-16-2008, 01:59 AM
  4. Underdrive pully
    By phoenix1987 in forum External Engine
    Last Post: 10-05-2006, 08:17 PM
  5. WTB:LS1 Underdrive pully
    By BBBBadSS in forum Parts Wanted / Trade
    Last Post: 02-02-2006, 01:35 PM
