Thread: proform rockers
    Jul 2009
    jacksonville Il.
    1998 ws6 trans am
    proform rockers
    Has anybody used proform bolt down roller rockers. I have some and have had several issues. 1. they hit the valve cover rail, 2. they hit the valve cover. 3. the stands are too tall and require longer pushrods. Just looking for feedback.
    Nov 2008
    Holiday,FL
    Green
    1997 Camaro Z-28
    I am guessing this is on an LS1. I just bought a set for an LT1 hope to be bolting them on my LE2 heads before new years.
    Member NoscamaroSS's Avatar
    Durant, Okla
    2002 Camaro
    We tried a set and they wouldnt even bolt down because they were hitting the valve cover rail.
    02 Camaro
    PRC Stg 2.5 5.3's, Futral F14, PP Typhoon intake, True duals, Performabuilt tranny, & 3500 convertor, HSW plate kit.
    *Old Time* 10.90@ 125mph
    St. Louis
    Blue
    Chevy Malibu
    Do not use anything made by PROCRAP.
    SBC roller tip rockers broke at the housing after 500mi, changed to comp roller tips and never another problem.
    Also almost wiped my brand new 406 sbc build with a proform small cap dist. ran for 5sec and then seized tight, thankfully it didn't wipe the cam out...junk junk junk
    Have not tried any LS1 Proform products -- their 2 piece timing cover I attempted to use for a SBC build was complete crap.
    Member crossbredfoxbody's Avatar
    First In Flight
    83 mustang coupe
    I installed a procomp gear drive on my old sbc I had and timing marks were not even close. There marks retarded my cam 9 degrees by setting there marks straight up. Also had a procomp tach once all of there stuff is junk.
    First In Flight
    83 mustang coupe
    It goes to say you always get what you pay for!!!!
    Jul 2009
    jacksonville Il.
    1998 ws6 trans am
    Thanks to those who replied, I returned the rockers and received a refund so I was only out my return shipping. I am going back to the stock rockers.
    Chicago
    2000 Z/28
    I would stay away from anything with the Proform name on it. I have heard horror stories about the needle bearings falling out of their rockers and making their way down into the oil pan. It's not worth it to lose an engine because you purchased a cheap part.
  1. Installing Proform short throw shifter
    By flotty in forum General Help
    Last Post: 05-01-2010, 05:20 PM
  2. are 243 OEM rockers the same as 853 OEM rockers
    By qwik219d9 in forum Internal Engine
    Last Post: 12-29-2009, 12:30 PM
  3. Proform Billet Shifter?
    By aerojt in forum Manual Transmission
    Last Post: 07-10-2007, 11:52 AM
  4. Engine Builders: Proform Dial Bore Gauge
    By xssive in forum Parts For Sale / Trade
    Last Post: 05-10-2007, 09:47 PM
  5. Proform 5" Tach
    By PARTSMAN84 in forum Parts For Sale / Trade
    Last Post: 09-20-2006, 07:26 AM
