    Member bberretta's Avatar
    Aug 2009
    Memphis, TN
    Bright Red
    2000 TA Firehawk 0041/742
    Help removing trans
    I'm in the middle of a clutch swap and I'm two bolts short of dropping the trans. Any tips on reaching the top two bolts that hold the trans to the bell housing? Keep in mind- I have no lift and I'm lying on my back on the ice cold concrete (thank God for the propane heater in the garage- it's hovering around 30 degrees tonight.
    Long extensions -- like a few feet worth with a swivel. Go raid your buddy's toolbox if you need to.
    Member 4thGenTA's Avatar
    Mar 2009
    farmington
    2002 firebird trans am
    +1 with the extensions, and be patient
    Aug 2009
    Memphis, TN
    Bright Red
    Driver side was okay, but holy crap, the pass side was a bear. Thanks for the help! Now if I could just get this damn Tick MS installed I'd be set.
    Aug 2009
    Memphis, TN
    Bright Red
    Another question: how difficult is it to replace the input shaft seal? Any guides or help would be great.
    Member camaroz98's Avatar
    Sep 2009
    las vegas
    blue
    1998 camaro z28
    Quote Originally Posted by bberretta View Post
    not to hard or to fun but heres the break down man. http://www.ls1.com/forums/showthread.php?t=107802 gonna have to go ass backwards from that tho unless you wanna break the whole thing down.
    Member chevyss1234's Avatar
    Feb 2007
    Clemson SC
    dude on the side, i have hardened engine mounts so i don't worry too much, but leave two bottom bolts tranny, drop the jack so the tranny hangs lower and make sure the intake is not hittin the firewall (don't wanna crack it) and you can get at those top bolts easier, do the same for puttin it back in, i also put the shifter on when the tranny is hangin like that.
  1. Question: Removing the a/c
    By sutie in forum Firebird / WS6
    Last Post: 04-20-2011, 09:51 AM
  2. Removing Trans with Solid Motor Mounts??!!!
    By bryceslu in forum Manual Transmission
    Last Post: 04-11-2011, 07:23 PM
  3. removing egr and air
    By jmatt07 in forum General Help
    Last Post: 03-12-2009, 08:18 AM
  4. Removing the AIR and EGR
    By Madcity T/A in forum External Engine
    Last Post: 08-02-2007, 03:16 PM
  5. removing axles on an 02 Trans AM
    By trainingdragon in forum Drivetrain
    Last Post: 07-16-2006, 12:37 PM
