    May 2008
    Virginia
    Metallic Blue
    2001 Trans Am
    Corvette rims on WS6?
    My question is this: Can I put the 17 x 9.5 front and 18 x 10.5 rear Zo6 rims on a 2001 WS6 that has been lowered about 1 inch? Will there be clearance issues? Or do I need to go with the 17 x 9.5 rims all the way around? Dont really want the rear wheels to stick out past the fender. Thanks for the help!
    I used to have that setup on my Camaro, with a 1.25" drop, you will be fine with that setup.
    May 2008
    Virginia
    Metallic Blue
    2001 Trans Am
    thanks for the info. What kind and size tires did you run? I am finding out that the rear tires are pretty pricey.
    18s are pricey. I ran 275/40/17 up front and 295/35/18 in the rear, BFG KDW in front, KDW2 in the rear.
    Member transamgirl89's Avatar
    Dec 2009
    Dacula, Georgia, United States
    2001 RS Camaro
    I have an RS Camaro and have the ZO6 rims on mine and it will work just make sure you roll the lip of the fender well if you do. I didn't do it to mine and it hacked up the tire. Of course I had spacers on the rear.
    May 2008
    Virginia
    Metallic Blue
    2001 Trans Am
    will I need spacers with Corvette Zo6 rims on the rear? If so what size? Dont really want the tires to stick out past the fender.
    May 2008
    Virginia
    Metallic Blue
    2001 Trans Am
    I found out that the offset for the front is +54mm on the front and +56mm on the back. Is there any need for spacers? Thanks for the help so far!
    Dec 2009
    2001 RS Camaro
    Quote Originally Posted by jcombs6337 View Post
    no not really unless you just want them. My Camaro has them and I had 1.25" spacers on there but it was for looks.
  1. Question: corvette rims on TA
    By ls1ws6ben in forum Firebird / WS6
    Last Post: 02-27-2011, 02:09 PM
  2. Wanted: Corvette Zo6 rims
    By jcombs6337 in forum Parts Wanted / Trade
    Last Post: 12-16-2009, 07:09 AM
  3. Help: Corvette C5 rims on 99 Z28?
    By 808chevyz28 in forum Wheels and Tires
    Last Post: 07-19-2009, 06:21 AM
  4. corvette rims
    By Al Hazz in forum Wheels and Tires
    Last Post: 09-27-2008, 09:15 PM
  5. Corvette rims
    By 98cam in forum Wheels and Tires
    Last Post: 02-25-2008, 07:27 PM
