Thread: Corvette C5 rims on 99 Z28?
07-15-2009, 08:48 PM #1Junior Member
- Honolulu
Black- 1999 Camaro Z28
I have some C5 Corvette rims(the thin spoke ones, F 245/45/17, R 275/40/18), and tried to put them on my 99 Camaro Z28.
My question is how do you get the rear tires/rims to fit? I was told that they would fit, but it hits on the front/inside portion of the wheel opening, and it seems to hit the bump stop also.
This was while at a shop with the rear axle hanging.
07-16-2009, 04:36 AM #2
they will go right on and be fine. on one of my cars, i had to massage the inner fenderwell in the rear front portion where the trailing arm is to clear the tire. hitting the bumpstop is only because it is hanging in the air. once you put the car on the ground, it'll clear.
07-16-2009, 06:30 AM #3King 0f n00bz
- Jan 2006
- Shepherd, Michigan
its my understanding that on maros a little mroe work at times could be needed compared to the bird on larger rim/tire packages ..but ^ mrr23 is right
07-16-2009, 07:05 PM #4Junior Member
- Honolulu
Thanks for the info, just wanted to make sure.
07-19-2009, 06:21 AM #5
I had to lift my from the axle and the rims fit just find without rubbing.
1996 Z28 LT-1 (with basic bolt-on)
Question: corvette rims on TA
By ls1ws6ben in forum Firebird / WS6Replies: 2Last Post: 02-27-2011, 02:09 PM -
Question: Corvette rims on WS6?
By jcombs6337 in forum Wheels and TiresReplies: 7Last Post: 01-09-2010, 02:14 PM -
Wanted: Corvette Zo6 rims
By jcombs6337 in forum Parts Wanted / TradeReplies: 0Last Post: 12-16-2009, 07:09 AM -
corvette rims
By Al Hazz in forum Wheels and TiresReplies: 1Last Post: 09-27-2008, 09:15 PM -
Corvette rims
By 98cam in forum Wheels and TiresReplies: 16Last Post: 02-25-2008, 07:27 PM
