Results 1 to 11 of 11
Thread: Top Sail Panel
12-11-2009, 05:51 PM #1
Top Sail Panel
would like to now how to remove the top sail panel does someone now the process to remove and install of new one ?
12-11-2009, 05:59 PM #2
Getting ready to do it myself. We have two threads on here that have some good info. I'll see what I can find...
12-11-2009, 06:00 PM #3
Here's the one I started: http://www.ls1.com/forums/showthread...placement+roof
12-11-2009, 06:01 PM #4
And the original: http://www.ls1.com/forums/showthread...light=bubbling
12-12-2009, 08:36 AM #5
good info thanks but i would like to now the process of removing it . i ve heard of just pulling it off and heard of using a wire with loops on each end like the ones plumbers use to cut through the glue .
12-12-2009, 09:07 AM #6
Either method works. As it can not be re-used, I will be breaking mine off in pieces. Will probably start with a small pry bar in an area that is not prone to damage. The surrounding areas will be taped off for protection.
02-12-2011, 09:14 PM #7
Jeff, why can they not be reused? Is it due the adhesive material used? Asking cause I got that crazy look in my eye and a scheme cookin'!
My bad on bringing up an oldass thread!
02-13-2011, 04:21 AM #8
02-13-2011, 06:04 AM #9
and if the sail panel in question does not have this problem and is bubble free?
02-13-2011, 06:05 AM #10
The sail panel is very,very flimsy..
It will more than likely break trying to remove it.
If you could get it off without breaking it, as stated the adhesive ruins the panel permanately..
02-13-2011, 06:47 AM #11
damn. i have a pristine sail panel (no bubbles) on a car that i was wondering if i could wire cut, remove, and sell.
Question: Sail panel? the small panel right behind the window
By Pony_Eater in forum Appearance SectionReplies: 4Last Post: 07-27-2011, 07:51 PM -
Question: New Sail Panel
By 02fbody35th in forum Appearance SectionReplies: 9Last Post: 04-02-2011, 10:59 AM -
Help: sail panel fix
By MudStainKILLA in forum Appearance SectionReplies: 4Last Post: 02-14-2011, 03:19 AM -
Wanted: New or Used Roof Panel (Sail Panel)
By dixielegger1 in forum Parts Wanted / TradeReplies: 2Last Post: 04-09-2009, 06:12 AM -
For Sale: Brand New Sail Panel (Roof Panel).
By cheetoh in forum Cowhands, Local Parts and Fish BaitReplies: 3Last Post: 04-06-2009, 11:46 AM
