Results 1 to 20 of 26
Thread: Bolt on Mods
11-23-2009, 08:25 PM #1
Bolt on Mods
Hey guys, new guy on the site. I'm really not looking to do any major internal work to the motor. Was shooting for 375-385 HP on basically bolt on mods? First Question. Can it be done usuing just bolt ons? Second Question. If so What's the best combo?
2002 Z28 Automatic.
Only Mod is Full Flowmaster installed before Purchase.
thanks
11-23-2009, 08:42 PM #2
I dynoed at 381 with just bolt ons and the mods in my sig
30th Anniversary Trans Am #0998
B&B triflow exhaust, American Racing Headers, RPM Level V T-56, RPS clutch, LS6 intake, P&P TB, Hotchkis lower trailing, Panard Rod, Tower Brace, SFC's, and Swar Bar Kit, BMR Lowering Springs, HAL Adjustable Shocks and Coilovers, Powerslot Rotors
11-23-2009, 08:44 PM #3
11-23-2009, 08:45 PM #4
Are you shooting for crank HP or wheel HP? I personally would target an E/T time and not a HP number.
The biggest bang for the buck with an A4 is a stall. A 3600 stall will reduce your E/T in the 1/4 by roughly .5 seconds I have read. Next I would think LTs (long tube headers). You could also purchase a lid. Headers I would guess would increase HP by roughly 30-35.
I have a M6 with some very good supporting suspension mods. The only HP adders I have done is LTs, exhaust, and a lid. I DYNO'd 330rwhp on a Mustang DYNO which would be about 360rwhp on a DYNO Jet. At the crank that would be about 400+ and that's going through a Moser 9" rear end, which takes a lot more power to drive. Thus, it's easily achievable.
11-23-2009, 08:51 PM #5
Thanks for the responses, to answer your question. Im not going to track it, and Im looking for 385 to the ground. Does me no good to have it at the crank and nothing to the wheels. I was looking at the SLP Full Induction, Not just the lid, has anybody had any real gains with them? What type of LTs do you have that give you 35? Thanks
11-23-2009, 08:54 PM #6
I would not purchase ANYTHING SLP (just my opinion and many others on this site as well). I have Kook's LTs, but they are pretty pricey as thy are one of the best available. If you are looking for the an affordable LT that is good quality, go with Pacesetters. There is also a sticky on here that Ron (Hi-Po) wrote up that will tell you everything you need to know about headers (brands, pricing, installing, etc).
11-23-2009, 08:56 PM #7
Here is the sticky on headers.
http://www.ls1.com/forums/showthread.php?t=126089
11-24-2009, 06:22 AM #8
the slp flow pac is pretty good i've seen .3 off 1/4 mile times with just that kit i know thats not what your lookin for but it's the only facts i can give you don't know the hp gain just know thats a good improvement for the $$
11-29-2009, 08:36 AM #9
I did a SLP lid, Fernco smooth bellows and SSRA. Together they made improved the power quite a bit. The catch can helped a small amount too. I haven't done a dyno. Very good gains in the country and on the highway.
You might want to focus on getting the power to the ground while you add it.
I just put SFCs on the car yesterday. No more squeeks at the bottm of the driveway or on railroad tracks. It launches straighter and with better control now. I did a shift kit a while back too. It just plain makes the car more fun.
11-29-2009, 10:50 AM #10
For being able to plant power to the ground better, you will want better lower control arms along with the relocation brackets for them. You will also want to look at an aftermarket torque arm.
11-29-2009, 11:00 AM #11
You are not going to see 380 anything to the wheels without going inside the motor especially an auto. I have every bolt-on and make 338hp 355tq(auto). You can do a cheater cam like a 218/226 115lsa and headers and still would probably fall a little short of the mark.
11-29-2009, 11:23 AM #12
11-29-2009, 04:41 PM #13Awaiting Activation
- Oct 2007
- NC
SOM- 1998 T.A.
11-29-2009, 05:00 PM #14Senior Member
- Oct 2008
- Coral Springs, Fl
http://www.ls1.com/forums/showthread.php?t=26836
helps a little
Like already said Headers, a Lid, You could Port your Throttle Body, There are some free mods you could look up as well like the Throttle Body bypass and the free ram air mod
These are just a start
11-29-2009, 09:59 PM #15
11-30-2009, 08:12 AM #16
Im at 336 with the stock Ypipe, Headers, no pulley upgrade and no dyno tune just mail order. I think with LT's, ORY, Pulley and a good dyno tune i should be about 360-365 RWHP and i have a M6 tranny. So getting to 375-380 will be very difficult and i have to agree with above doing stall, gears will make your car very quick especially in the quarter mile.
1993 Z28 M6: K&N Intake, 52mm TB, TB Bypass, No Cats, Exhaust Cutout, Flowmaster Muffler, 3.90 Gears, 160 Thermo, Tune, BMR Springs, Bilstein Shocks, 3 Point SFC,s & MGW Shifter.
11-30-2009, 01:48 PM #17
these guys say thay can do it
http://www.speedengineeringanddyno.c...Records-02.htm
11-30-2009, 01:53 PM #18
11-30-2009, 02:02 PM #19
They are extremely vague in there explantion, reminds me of someone who bought the p1sc because the tuner said it would give them 500hp. Then they realized they meant at the crank not at the wheels.
"400 rwhp LS1 X package (external bolt-ons)
The X package consists of a combination of components that work in harmony together with custom tuning to produce the absolute maximum power gains without the use of power adders and without heads and cam. It was first developed on an '01 Z06 Corvette in 2001. This car ran 11.44 @ 122 mph when most cars with heads and cam weren't running that well. This was a daily driver with the stock gear and at full weight. The perfect combination of parts and precision tuning is the key to the X package and the X package is the key to getting the most power available from a Naturally Aspirated Stock long block. Some people like not changing heads and cam because it allows them to maintain the factory warranty. Some people just don't want the "race car" sound or give up the drivability that comes with a cam. Some people just want to have as much power as a lot of head/cam packages are providing so that when they do heads and cam they will be well ahead of the game. No matter what you want, the X package gives the absolute most power available from external bolt-ons. We can also modify this package to work on other LS1 Vehicles as well as LS6, LS2, LS3, LS4, LS7 and LS9, with each one making more power respectively. Check out the LS1 F-body X package Dyno here - 400 RWHP - naturally aspirated - without heads/cam. The X packages are available only as in-house turnkey packages."
12-01-2009, 12:06 PM #20
look into getting around a 3,600 stall and longtube headers 1st.
I'm running a 3,800 stall with H/C and DD my goat 60+ miles a day........best part of the day is my commute to and from work
bolt ons mods
By FMR_TransAm in forum External EngineReplies: 43Last Post: 02-06-2012, 04:37 PM -
Question: Best low cost Mods and bolt ons ?
By DirtyJerzZ28 in forum External EngineReplies: 29Last Post: 07-11-2010, 07:08 PM -
Bolt-On Mods Continue: all done after this...?
By SSwt00SS in forum External EngineReplies: 67Last Post: 08-31-2008, 10:59 AM -
Need Advice On Bolt On Mods!!!
By L3THAL_Z28 in forum Camaro / SSReplies: 26Last Post: 08-24-2007, 11:26 PM -
What are best bolt on mods?
By VinceWS.6 in forum Firebird / WS6Replies: 4Last Post: 10-05-2006, 01:37 PM
