Thread: LS1/LS6 intake swap question
11-15-2009, 08:57 AM #1
I just picked up a 2002 intake for my 00 WS6. The part number is 12561184, From all the searchs I've done, it's a LS6 from an 01,02 F body. However it does not have the flat bottom like other descriptions I've seen. When I swap this intake over, do still need to reroute the water lines under the Intake? Is it a true LS6 intake or am I just wasting my time swapping it out?
11-15-2009, 10:22 AM #2Junior Member
- Jun 2009
- north central illinois
artic white- 2001 trans am ws6
dam, thats a good question, ill look some stuff up and see what i can do. if i cant find anything i can atleast say best of luck finding that out cause i would like to know that answer to.
11-15-2009, 04:50 PM #3Just me
- Nov 2006
- Broken Arrow, OK
Can you post a picture of the bottom of it?
The part number you listed is for an LS6 intake. I would like to see the bottom of it though.Last edited by Y2KPewterSS; 11-15-2009 at 04:53 PM.
11-16-2009, 05:00 AM #4Junior Member
- Oct 2009
- usa
red- 1965 nova
if you look at the front leading edgeand it has a wing type shape it is a ls-1 on the ls-6the front edge is straight across,looking at the bottom if it is flat with no shape that is an ls-6 ,hope this helps
11-16-2009, 06:13 AM #5
Yeah, I agree with you on the shape, but mine looks like an LS1 intake, but the P/N says it's a LS6. It's off of a 2002 SS Camaro. Here are the pics.
11-16-2009, 06:57 AM #6Senior Member
- Jul 2005
- Jacksonville, FL
That's a LS6 intake, bottom is flat. You'll need the LS6 front coolant pipe and rear plugs - unless you want to grind down the ridges a little to make room for the LS1 pipe.
11-16-2009, 07:05 AM #7
That's cool, I was really wondering if I got fooled by the seller. Picked the whole Intake and TB up for $200. I'll grind down the ribs to make room for the waterpipes under it. I also plan on cleaning up the throttle body and polishing it up. Any other throttle body free mods?
11-16-2009, 07:09 AM #8Senior Member
- Jul 2005
- Jacksonville, FL
This shows the difference, the LS1 is the one on the left: http://www.ls1howto.com/howto/geniii...//IMAGE009.jpg I'd replace the gaskets too.
Question: HOW TO: Swap stock intake with LS6 intake
By thechad125 in forum General HelpReplies: 18Last Post: 02-26-2013, 03:17 AM -
ls6 intake swap
By oldpurple73 in forum External EngineReplies: 6Last Post: 06-30-2011, 03:59 PM -
Question: intake swap question
By sutie in forum External EngineReplies: 6Last Post: 10-12-2009, 03:16 PM -
Intake Swap Question
By splitfinger09 in forum External EngineReplies: 10Last Post: 05-08-2008, 12:19 AM -
Ls1 to Ls6 intake swap, anything i need to know?
By 2MuchFun in forum General HelpReplies: 13Last Post: 09-26-2007, 07:02 PM
