    ls1 powered seabee sutie's Avatar
    oxnard, ca.
    red and black
    1999 Formula/WS6
    intake swap question
    so ive done my research, got all the parts i need, talked to people about the swap, im finally starting it tonight. i was just curious if by expierience, you know of any special tools or tricks to help the swap go a little smoother. please let me know so i can get what i need to make this as little of a headach as possible. thanks yall!
    Member stephen02ws6's Avatar
    Dalzell, Illinois
    red with black stripes
    2002 Trans Am WS6
    take the coils off on at least the passenger side, it helps give you room to get to the back bolts. as far as tools all you need, off the top of my head, is an 8mm and a 10mm socket and a screwdriver. if you are automatic, you might want to unbolt the trans dipstick to get at the back bolt.
    oxnard, ca.
    red and black
    1999 Formula/WS6
    good to know, thanks.
    Senior Member clg82's Avatar
    Feb 2007
    California
    2000 Trans Am
    Also just to add to that, be VERY VERY careful of the "Oil Pressure Sending Unit" directly behind the intake, if you aren't careful you will break it off, and then you need another tool to remove the old one and that can be a bitch.....wear gloves too or else your hands will be scratched to shit!
    oxnard, ca.
    red and black
    1999 Formula/WS6
    haha, found that one out the hard way, replaced the sensor...and a few other things. thought i figured out my oil leak too, the knock sensor oil seal was bad and the valley was flooded with oil, replaced both seals and sensors and OPSU, torqued everything back down....low and behold....another leak! im loosing my mind here! no idea were its leaking now, ugh!
    We'll be back... GatorSS's Avatar
    THE SWAMP
    Light Pewter Metallic
    2000 Camaro SS M6
    Gloves, definitely! And we aren't talking latex gloves, either. You need gloves with some substance to them, because latex gloves can easily be cut to shreds.
    oxnard, ca.
    red and black
    1999 Formula/WS6
    yea, hands look like i got into a fight with a weed wacker and i got my ass kicked......
  1. Question: HOW TO: Swap stock intake with LS6 intake
    By thechad125 in forum General Help
    Last Post: 02-26-2013, 03:17 AM
  2. ls6 intake swap
    By oldpurple73 in forum External Engine
    Last Post: 06-30-2011, 03:59 PM
  3. LS1/LS6 intake swap question
    By beach cruiser in forum External Engine
    Last Post: 11-16-2009, 07:09 AM
  4. Intake Swap Question
    By splitfinger09 in forum External Engine
    Last Post: 05-08-2008, 12:19 AM
  5. Ls1 to Ls6 intake swap, anything i need to know?
    By 2MuchFun in forum General Help
    Last Post: 09-26-2007, 07:02 PM
