Results 1 to 14 of 14
    Junior Member BamBam87's Avatar
    Jun 2009
    north central illinois
    artic white
    2001 trans am ws6
    headers question
    when i get my headers and i get ready to put them on........do i have to take the engine out or can i leave the engine in and change it like that? i know there isnt alot of room on the sides but i wasnt all the way sure.
    Master Tech SSDEUCE's Avatar
    Jul 2009
    crownsville MD
    navy blue metalic
    2001 camaro ss
    engine stays in the car some brands slide in from top or bottom don't freak though if you need to dent a tube or two there not all perfect
    Member NoscamaroSS's Avatar
    Durant, Okla
    2002 Camaro
    02 Camaro
    PRC Stg 2.5 5.3's, Futral F14, PP Typhoon intake, True duals, Performabuilt tranny, & 3500 convertor, HSW plate kit.
    *Old Time* 10.90@ 125mph
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    keep the engine in..you will free up quite a bit of room when you take the old exhaust out....go from the bottom ....check your clearances before you bolt the headers completely up..some trimming might be needed...and while you are there..change your motor mounts...TRUST ME!
    Quote Originally Posted by NoscamaroSS View Post
    Chuckie above and my thread below should answer all your questions. But if you have any feel free to ask.
    http://www.ls1.com/forums/showthread.php?t=122035
    Quote Originally Posted by BamBam87 View Post
    What are you putting in, LTs, Mids, shorties?
    Jun 2009
    artic white
    2001 trans am ws6
    you know im not really sure what kind i want to put. i dont know all my options yet but now that i know i have to pick from LT's, mids and shorties.......so what is the normal pick for a person trying to get headers?
    Shepherd, Michigan
    98' trans am
    dont take this the wrong way..but you might be over your head a little on installing these headers..that is unless you can use a lift..are comfortable with a sawzall or getting under your car and jacking your car pretty high.
    Jun 2009
    artic white
    2001 trans am ws6
    i dont have a problem doing any of the maintance. i just want to know whats best before i get it. i know i can jack my car up pretty good on my jacks that i know of and using a sawzall.......that should be fun as hell. i just dont want to mess anything up so i am just double checking by asking
    in my Trans Am
    2000 Trans Am WS6
    you wont have to take the engine out, some people have had to notch their k member though. Also try and get gm gaskets if you can.
    Quote Originally Posted by TransAm11973 View Post
    x2
    If emissions are not a problem get LT's, 3" ORY (Off Road Y-pipe), Cut Cats, and get either a CAT Back System or not.
    I have cut my CATs and have a Magnaflow muffler
    LT's by far.... mids and shorties are imo a waste of money... check out eh ebay header thread... that's what i got $220.00 to my door...
    Member BirdCountry02's Avatar
    Feb 2008
    Virginia
    Maple Red Metallic
    2002 Trans Am M6
    You'll be fine with the engine in, read the sticky it'll help alot. Just know when your done, your gonna wanna delete your AC
  1. LT headers question
    By Azchan63 in forum External Engine
    Last Post: 11-23-2014, 02:14 AM
  2. Headers question
    By Dave-TransAm in forum LT1
    Last Post: 03-26-2011, 08:30 AM
  3. Question on headers
    By 99WickedSS in forum External Engine
    Last Post: 03-20-2011, 02:28 PM
  4. Headers question
    By turyg ls1 in forum External Engine
    Last Post: 08-23-2010, 08:46 AM
  5. Question about headers
    By Z ROADSTER in forum External Engine
    Last Post: 08-24-2009, 01:43 PM
