Results 1 to 14 of 14
Thread: Gas Stabil or not?
10-29-2009, 02:57 PM #1Junior Member
- Oct 2005
- VA
Black- 2002 Trans Am Firehawk
Gas Stabil or not?
My 02 hawk spends 98% of its life under car cover in my garage.I have turned just over 4000 miles.So, my question is about gas stabalizer.Anyone use that stuff?I just don't like the idea of adding stuff in the gas?
Any thoughts?
10-29-2009, 03:50 PM #2
if its sits that much i would use it, i used to put it in ever time i filled up b/c it takes me weeks to get through a tank of gas
10-29-2009, 03:57 PM #3
I use it when my car goes into storage.
10-30-2009, 07:44 AM #4
I use it too....including all of my yard equipment and jet ski.
10-30-2009, 12:19 PM #5
I use it every time I put my car into storage
Which unfor happens way too often
┌∩┐(◕_◕)┌∩┐
wouldn't want to fight them!
10-30-2009, 12:23 PM #6Senior Member
- Jun 2008
- Rochester, NY Rochesterracing.com
- 2000 Camaro B4C
use it once a year....the saddest day of the year when my car goes by by for the winter.
which unfortunately is next week...damnn2000 B4C Special Service Package Z28 - Kooks 1&7/8 Stepped 2'' - TSP Torquer V.2 - FAST 92/92 - BDR 4000 Conveter - Xtreme Trans Stage II - Full UMI Suspension - Pacesetter LT's - Comp Drag Shocks - Magnaflow - Cutout - ZO6 MAF - FTP LID - Street Tuned -
10-30-2009, 02:18 PM #7
It's more important for 2-strokes...but yeah, go ahead and put it in there if the gas stays in it for a while w/o use.
dale
11-01-2009, 07:22 AM #8Junior Member
- Oct 2008
- Michigan
SOM- 2001 WS6
I've used it the last couple of years for winter storage. No problem. I usually run it a couple of times during the winter months. Got a battery tender this year and not planning on firing it up.
11-01-2009, 08:28 AM #9
I have used it for years with no issues. I'm not sure how much it helps, but it is cheap enough to warrant even a slight amount of protection from moisture and varnish.
11-01-2009, 08:37 AM #10
My car sits in the garage as much as the OPs car. I have always been afraid to use it
11-01-2009, 08:45 AM #11Junior Member
- Oct 2009
- Dearborn hts,mi
opel blue- 1999 Olds Alero
Well if you dont use it then the gas will varnish up and clog up your fuel line and wont let you start up you car in the spring. IMO full tank and add staibl as directed..
i use it all the time.
11-01-2009, 08:50 AM #12
11-01-2009, 11:29 AM #13
Like I said b4, it's more important for 2-strokes b/c a lot of them have fuel tanks that are openly vented to the elements, and the ethanol in 2day's gas absorbs water which stabil helps prevent. It won't "hurt" anything to use it....only helps.
11-02-2009, 08:48 PM #14
I went ahead and bought some Sta-bil. The only concern I have to adding anything to the fuel is the O2 sensors getting messed up. I had a bad spark plug one time and thought I had gotten some bad gas-so I put some octane boost(the $7 kind) in my tank and it made the o2 sensors turn a bluish color.
If all of you guys use it with no issues should be fine. I guess I worry a bit too much.
stabil for winter or no
By mammoth713 in forum Camaro / SSReplies: 8Last Post: 09-29-2010, 01:25 PM -
Stabil
By TransAm11973 in forum General HelpReplies: 8Last Post: 08-11-2009, 12:41 PM -
Question: Stabil
By The Silver Goat in forum GTOReplies: 7Last Post: 01-13-2009, 01:19 PM -
Stabil and fuel treatment
By slikws6 in forum General HelpReplies: 7Last Post: 12-01-2008, 04:32 PM
