Results 1 to 10 of 10
Thread: Stuck In WOT??
    R.I.P. LS1 LS1Power06's Avatar
    817, Texas
    03 Terminator
    Stuck In WOT??
    Every once in a while, occuring more often as time goes on, my camaro seems to get stuck in WOT after i get on it for a little bit. Ill haul ass for a bit, then let off and push in the clutch, but the RPMs stay up at 5K+ for a few seconds and then it slowly drops. What is causing this and how can i fix it? Thanks
    RyAn
    MEMBER 5150's Avatar
    Visalia Cali
    SILVER
    2000 Z/28
    sticky throttle cable, maybe. try spraying some wd-40 inside the cable but first with the car off, unhook the cable from the tb if that moves freely it is more than likely the cable or possible something with the pedal itself.
    Awaiting Activation Liquifire's Avatar
    central wisconsin
    I know it sounds foolish, but make sure that your floor mats are clear of the pedal @ WOT........
    Member Capster78's Avatar
    Newport News Va
    1998 WS6 M6
    Probably need to clean the MAF to.. just watch out for the sensor.. dont want to get that wet.
    Member jmhvenom's Avatar
    Cincinnati, OH
    2002 Z28
    Yea I cut the piece out of the top right of my floormat. It definatly hits it, and even was keeping it from going down all the way to the floor. But i would recommend something else for lubricant since WD40 is a penetrating oil..
    Blown, Stroked, & Sprayed
    Ed Blown Vert's Avatar
    Aug 1999
    No Where
    383 Procharged & N20 Vert
    Quote Originally Posted by Liquifire
    I have seen this happen many times.
    Forged 383 | ATI D-1SC
    NX MAF Kit | 222/226 .585 115
    AS Stage II 6.0L FI Heads
    817, Texas
    03 Terminator
    Quote Originally Posted by jmhvenom
    well what would u recommend then? anyone else can chime in with what i should use if not WD-40. thanks
    RyAn
    Single Malt rbob93's Avatar
    Ft. Lauderdale, FL
    Sebring Silver
    2000 CamaroSS
    Quote Originally Posted by LS1Power06
    RyAn
    Kroil.
    Retired Outlaw Sum Bitch
    Probably a mechanical issue like everyone is saying...but a vacum leak can cause a WOT condition that slowly works its way back down also...just FYI...
    817, Texas
    03 Terminator
    alrite i will look into it further and maybe try some kroil. thanks for all the help!
    RyAn
  1. I'm stuck in between
    By cobrakiller99 in forum Firebird / WS6
    Last Post: 02-20-2009, 04:38 PM
  2. Help: Uh Oh, I'm Stuck
    By kool-aide in forum Suspension and Handling
    Last Post: 09-03-2008, 04:16 PM
  3. Stuck in 4th
    By AgitatedPancake in forum Manual Transmission
    Last Post: 04-11-2008, 12:55 PM
  4. Stuck on what to mod next...
    By TransAmcoupe98 in forum Internal Engine
    Last Post: 01-09-2008, 09:17 PM
  5. Stuck on what to mod next...
    Last Post: 01-08-2008, 07:32 AM
