Results 1 to 20 of 32
    - STOCK ish - Sarge91's Avatar
    Fairhope, Alabama
    2002 Camaro SS SLP
    ET Street Radial or NT555R?
    So im trying to figure out what the best DR i can get. The car is my DD and it does see rain, i know that the Nittos can handle rain, how bout the ET's? I run the regular NT555 street tires right now, cut a 1.82 60' with em, but i need a drag tire!
    Also the ET's are cheaper. Suggestions?
    275/40/17 is what im going to get.
    Thanks
    2002 Camaro SS A4 - SLP# 2951 l MS4 l LT's w/ORY l F.A.S.T 78 & TB l Borla l Cutout l CME l TCI 3500 l 3.23's l !emissions l !sway
    Coral Springs, Fl
    Sunset Orange Metalic
    Quote Originally Posted by Sarge91 View Post
    Thanks
    Heard the nittos suck at the track
    ETs are not so good on the highway
    If i were you i would find a spare set of rims for some ETs
    Member stephen02ws6's Avatar
    Dalzell, Illinois
    red with black stripes
    2002 Trans Am WS6
    you have to heat the nittos up at the track. i can hook fine on mine. i cut 1.70 60' now but i think i can break into the 1.6s when i go on the 18th.
    Feb 2008
    NEW JERSEY
    PEWTER
    2001 TRANS AM WS6
    ET = strip/street
    nitto = street/strip
    Member 346ci's Avatar
    AK
    1998 Z-28
    I have M/T on another set of rims for track and special outings, hook real nice. I have no experience with the Nittos
    Veteran 35th-ANV-SS's Avatar
    Wherever life takes me
    02 35th LE Camaro SS
    Quote Originally Posted by stephen02ws6 View Post
    What is your set-up? What are you launching and how much pressure are you running with them? Thanks...
    Rice Killa JwMonE99's Avatar
    Aug 2006
    Myrtle Beach
    Black With T-Tops
    96 Z28 M6
    Is there any place besides discount tire direct that has nitto 555R cheaper then $313 shipped for 275/40/17?
    Quote Originally Posted by JwMonE99 View Post
    When I bought mine a few months back, DT was the cheapest I found.
    Dalzell, Illinois
    2002 Trans Am WS6
    if that is for both its good. about what i paid for mine. i got minne from american muscle since one of my friends had a discount code from the mustang forum. with the discount i got them for 300-310 shipped.
    im cammed, 3500 stall, 3.73 gears, and rear suspension. i launch about 2000 rpm or a little higher. i drop the pressure down to around 20psi. i do a nice burnout before the line.
    Thanks for the info. I just went to the track and ran with Nitto's for the first time. Best 60' I could pull over 3 runs was 1.905 dropping it from 3500RPM. I'm a M6. Was running 22PSI.
    My car makes a decent amount of power....and is a manual.
    I have cut 1.86's on the Nitto's.
    I have cut 1.69 on the MT radials.
    Spinning to 1.67 on the Hoosier QTP's.
    Nitto's are the only drag radial I would drive in the rain.
    Member c5z28's Avatar
    Bay Area
    On your ass flashing
    my highbeams
    I'm cutting 1.9's with the 16" snowflakes and stock tires
    I need MT's!!!
    Wisconsin
    2001 Camaro SS M6
    Excellent info I was wondering about Hoosiers and how good they were. What size tire you runnin?
    ┌∩┐(◕_◕)┌∩┐
    wouldn't want to fight them!
    Fairhope, Alabama
    2002 Camaro SS SLP
    I can cut a 1.75 60' on the regular nitto street 555's.. so im sure i can get a low 1.6 on the R's
    I can get the 555R for 159 each, or the ET for about 200 each.. so im still looking.
    I would watch any DR on the street and no way I'd want caught in the rain with MT's. I about lost my car several years ago when I got caught in a rainstorm with nitto's. Just cruising along at 55 and the backend jump out from under the car. They had some miles on them, ~10k I think so they were getting close to done.
    As far as at the track I've cut a 1.71 on Nitto's and a 1.6x with MT's. Had a line lock with the MT's but not the nitto's.
    drop that pressure to 15 and it'll make a pretty big difference.
    Shepherd, Michigan
    blacker than wesleysnipes
    98' trans am
    for you op i would suggest the nittos ..they are the only DR i know that can handle street decently ..at the track..drop the psi to 15 and light them up good for the best times...BUT MAKE SURE YOU UP THE PSI before you leave if you can.
    Omaha, NE
    2000 Z28 Camaro
    I can't hook with the 555R's, decided to do a few suspension upgrades and we will see.
    Thanks. I plan on getting back out this spring. I went late in the year so I am thinking the track conditions and weather weren't ideal for me as well.
    Hi-po was also telling me that I should try feathering the clutch out some with using the Nitto Dr's.
    I was dumping it, which was causing a lot of bad wheel hop.
    Ultimately, I want to be running M/Ts or straight slicks to test this 9" out.
  1. Nail in my et street radial HELP!! 255
    By leod123 in forum Wheels and Tires
    Last Post: 06-16-2008, 05:29 PM
  2. 16" MT et street or RADIAL??
    By greatwhiteZ28 in forum Wheels and Tires
    Last Post: 10-30-2007, 01:24 PM
  3. poll for street radial. Nitto 555r or m/t new et street?
    Last Post: 04-09-2007, 08:58 AM
  4. New M/T street radial
    By clint195 in forum Wheels and Tires
    Last Post: 04-08-2007, 01:41 PM
  5. 0-60 drag radial improvement on the street?
    By lukasink in forum Wheels and Tires
    Last Post: 11-13-2006, 04:03 PM
