Results 1 to 18 of 18
    Senior Member Zboner's Avatar
    cincinnati/northern ky
    99 SS
    rear end gear fluid
    got a 2000 WS6 T/A
    what is a deacent gear oil to run? how many quarts for the rear?
    what mix also? like 80/90 or something?
    what is a good additive for the posi?? how many bottle thingys will i need for that?
    is Lucas ok?
    LS1 Noob
    Fredericksburg, VA
    2000 WS6
    I'm doing a girdle and stud kit tomorrow and will be using Mobil 1, 75W90 with one 4oz bottle of GM LSD additive. I've read (using the search button on various LS1/FBody sites) that you'll use about a bottle and a half of gear oil.
    Marc
    joel, can you get that, hoss?
    Commerce Ga
    Black, Blue
    07 TBSS, 07 GSXR1000
    The easiest way is buy GM additive and buy 2 quarts of the gear lube that your running. Add the additive first and then add the gear lube till it starts to come out. Then you know it is full.
    use the whole additive or just half?
    cleveland ohio
    trans am 00 ws6
    1998 camaro ss vert
    i see that all makes sense.
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    Use the entire bottle of additive, it is 4 or 6 oz.
    Just to put some mess into the game, I run 85W/140 dino oil in my differential on my 01 Z28.
    SteveC
    Member Transam388's Avatar
    Cypress, TX
    98 Trans AM
    Royal Purple makes great stuff and I would highly recommend their gear oil. It aint cheap but it does a great job of reducing wear and friction!!
    Quote Originally Posted by SteveC
    SteveC
    define "mess"
    I Fixed Da Rear jimbo98z's Avatar
    Raleigh, NC
    Mystic Teal
    1998 Z28 M6
    Quote Originally Posted by Transam388
    Agreed. Royal Purple is the balls . I run their motor oil as well as their gear oil. I run 75w90 with the whole bottle of GM posi additive. Also, make sure you don't overfill the rearend. Fill till it starts coming out, then let it drain until it stops coming out. And make sure you're on a flat surface. Too much is actually a MUCH worse problem than too little in this case.
    GM additive # 1052358
    I have a bottle here waiting to get dropped in.
    Royal Purple gear oil is a great choice.
    Lowered, HID's, tinted.
    Alcohol Injected PaganEgyptian's Avatar
    Knoxville,Tn
    1999 Pontiac Firebird
    ....Pennzoil Full Synthetic 75W90 and I dont use GM Limited slip with Brass clutches. -Tim
    Poway, Ca
    SOM
    2001 Z28 (Sara)
    Thumbs up
    Quote Originally Posted by dipherentdesign
    define "mess"
    Controversy.
    SteveC
    near St. Louis
    navy blue
    2002 Z-28 Camaro M6
    If I remember correctly in 99 they went to a torsen thextal (spl?)differential-a torque sensing job that doesn't use clutches in there to provide the limited slip part of it.I know my 98 required the additive and my 02 does not. Realizing this my be too late-if you put it in there don't worry about it-it won't hurt anything either to my knowledge.
    Retired Outlaw Sum Bitch
    Royal Purple.....you lil shit....
    Junior Member uwilluz's Avatar
    Feb 2006
    michigan
    black black pewter
    89,00 LPE WS6,02 LPE WS6
    if your using royal purple you must not be road racing the or have close to stock horsepower, because i cant keep the stuff from puking out all over the driveshaft and then being flung on to the exhaust.(nice smell) i never had this problem with the stock gm fluid. and will be going back to stock or trying out mobil one.
    83 Firebird SCCA Race Car, 89 WS6 T5 SCCA Race Car 00 Lingenfelter WS6 T-Top 6spd Transam, race suspension, baer brakes, 02 Lingenfelter WS6 vert 6spd Transam, 1971 LT1 Vert Corvette, 06 Ext Cab Z88 5 spd Canyon, 08 Z71 Ext Cab Sierra
    Member keliente's Avatar
    Charlotte, NC
    99 Firebird Formula
    You guys are nuts with the synthetic/overpriced rear-end fluids.
    It is not necessary to pay upwards of $10/qt for gear lube unless you are doing road racing where you would sustain 150mph+ for hours at a time, thus causing the fluid to boil.
    I don't use anything but generic 80w90 on mine...it's not only daily driven, but takes a weekly thrashing at the track, usually 20 or more passes on 4,500k launches (M6).
    Senior Member
    Jacksonville, FL
    I changed mine and went with what was recommended in the owners manual for the LSD - SAE 75W-90 synthetic, and a 4oz bottle of additive.
  1. rear end fluid coming out of the rear tire
    By stangkillan101 in forum Drivetrain
    Last Post: 06-24-2011, 07:42 PM
  2. Changing trans fluid and rear end fluid
    By 98Z28importslayer in forum Drivetrain
    Last Post: 07-29-2008, 08:33 AM
  3. with rear gear fluid change.....
    By clg82 in forum Drivetrain
    Last Post: 07-23-2008, 12:26 PM
  4. Rear end fluid?
    By Hot Rod SS in forum Drivetrain
    Last Post: 12-17-2006, 09:27 AM
  5. 98 Z28 clutch fluid low, won't go in gear... HELP!
    By Motrv8d Steve in forum General Help
    Last Post: 04-06-2006, 12:58 PM
