Results 1 to 13 of 13
    Apr 2009
    Palm Desert, CA
    97 3.8L Firebird 5 Speed
    Grinding Reverse
    I have a 97 V6 3.8L 5-speed
    I am kinda new to manual but I have a question
    Almost every time I shift into reverse it grinds(YES, I am at a complete stop), I cannot figure it out, and the Transmission has a burning smell if it grinds (Note to my Burning smell post, Its the tranny I think)
    What could it possibly be? I'm scared to drive it now since I don't want to buy a tranny
    Pittsburgh
    2008 Hummer H3
    Quote Originally Posted by Conflict View Post
    It's quite possible you're losing reverse.. Does it pop out of reverse when you back up?
    Pittsburgh
    2008 Hummer H3
    Also, has the car ever been stuck in bad wheather, beach, mud?
    Pittsburgh
    2008 Hummer H3
    The smell could also be comming from your clutch.. A worn out clutch can make it hard to get into gear, aswell as a bad slave cyl.
    Apr 2009
    Palm Desert, CA
    It doesn't pop out of gear when I'm in reverse, not sure about the mud/beach thing but I live in a desert and the car was from a part of LA, no really bad weather around. I guess it might be the clutch...
    Pittsburgh
    2008 Hummer H3
    Okay then proly not the trany then.. If your mileage is getting up there it probably is the clutch..Since there's no way to tell how the last person drove it..
    Apr 2009
    Palm Desert, CA
    it was a women, but its only in reverse..., is the grinding bad for the tranny or is it bad for the clutch?
    Member nillam1's Avatar
    Apr 2009
    Toronto, Ontario, Canada.
    2002 Camaro Z28
    This used to happen to me in an older Camaro I used to have. Try shifting to first before reverse! This worked for me.
    2002 Camaro Z28 Bolt ons, Flowmaster catback w/3" QTP electric cutout, Superchips tuned, Granatelli MAF, SLP cold air induction Lid & filter, ZEX powertune plugs, Taylor 10.4mm wires, 160 T-stat w/fan control, Eibach sportlines & BFG-KDW's on 17" SLP SS rims.
    Pittsburgh
    2008 Hummer H3
    Well it's not the best thing for the tranny that's for sure. I'd have it serviced soon..
    Member bryceslu's Avatar
    Chicago, IL
    00 NHRA Formula
    Quote Originally Posted by nillam1 View Post
    Not sure about 1st to R but 2nd to R works like a charm.
    Apr 2009
    2002 Camaro Z28
    Quote Originally Posted by bryceslu View Post
    Our newer 98-02 LS1's have a tranny that can be shifted to reverse, even while still going forward slowly or just having pressed the clutch in after moving forward. That is why we get no grinding when shifting to reverse. Older tranny's did not have that.
    You can get it serviced like SMITTRO suggests but if shifting to 2nd before shifting to reverse get's rid of the problem, then just get in the habit of doing that. Nothing wrong with your tranny.
    Member clovenhooves's Avatar
    Jun 2009
    CA
    When my previous car (automatic) was having that problem, it was the transmission.
    Chicago, IL
    00 NHRA Formula
    Quote Originally Posted by clovenhooves View Post
    Completely seperate application
  1. Help: Transmission jumping out of reverse and now grinding..
    By CHEVELLE6808 in forum Manual Transmission
    Last Post: 08-15-2012, 07:09 AM
  2. Grinding in 3rd and 4th
    By jmhg220 in forum Manual Transmission
    Last Post: 11-13-2009, 08:38 PM
  3. Grinding....??
    By BlueMagicSS in forum Manual Transmission
    Last Post: 01-20-2008, 07:44 PM
  4. Grinding
    By steven strickland in forum Manual Transmission
    Last Post: 08-12-2007, 07:09 PM
  5. Grinding in reverse
    By rajiv1998 in forum Manual Transmission
    Last Post: 11-17-2006, 11:17 AM
