Thread: Grinding in 3rd and 4th
11-12-2009, 03:02 PM #1Junior Member
- Nov 2009
- Virginia
Black- 2001 Camaro
Just got a 2001 Camaro, LS1, T56 - There is resistance (and subtle grinding) going into 3rd and into 4th and it sometimes pops out of 4th. I have been told everything from: Add some fluid to complete rebuild. Please give me some ideas on how to smooth this out. If it is just the syncro, what should that cost to fix? Can I do it myself? Can you refer me to good esources.
Also the speedo reads about 47 MPH at 65 MPH - Any help with that?
11-12-2009, 05:13 PM #2
Sounds like a synchronizer assembly to me. When blocker rings get worn, they can create clash when you try and engage a gear, especially while moving. If the synchronizer assembly becomes very worn, it can also allow the trans to pop out of gear.
In order to correct the issue, the trans would need to be disassembled and serviced.
11-13-2009, 04:56 AM #3Junior Member
- Nov 2009
- Virginia
Black- 2001 Camaro
Thanks Wesman, Does anyone know what this should cost? The quotes I have heard sound like a complete rebuild.
11-13-2009, 07:34 PM #4
In all honesty, if you're going to go through the trouble to fix the 3-4 synchro/shift fork, you might as well do a rebuild while its all apart. At the very least, change blocker rings, shift keys, fork pads, and seals.
As long as the synchro hubs, gears, and bearings look fine, they shouldn't need to be changed though.
11-13-2009, 08:38 PM #5
dude fuck it and go with the viper rebuild, i wish i had the number still you can send your tranny in and for 1800 bucks get the viper rebuild indestuctble T-56
Help: 1st to 2nd grinding
By egod in forum Manual TransmissionReplies: 21Last Post: 09-13-2009, 06:40 AM -
Question: Grinding 2nd
By 173rdbrandon in forum DrivetrainReplies: 2Last Post: 12-02-2008, 08:44 AM -
Grinding....??
By BlueMagicSS in forum Manual TransmissionReplies: 2Last Post: 01-20-2008, 07:44 PM -
Grinding
By steven strickland in forum Manual TransmissionReplies: 0Last Post: 08-12-2007, 07:09 PM -
GrindinG !!!!!
By JattGunMan in forum Manual TransmissionReplies: 0Last Post: 07-19-2006, 10:53 PM
