    Sep 2009
    mattawan
    Vats Bypass or Air bag?
    Vats Wire or Airbag?
    Is this the vats connector, or is this the air bag wires??
    Hi so I did the vats bypass on my 98' Aurora I thought it worked but a day later im still having the security light come on, and my air bag light is on. Maybe I put the resistors on the air bag connector? Besides the color of the wires being different (the normal two white wires/and purple) and mine had a white and a green wire sleeved in yellow tubing, and on the other side of the connector was green and white again. These are the only wires with a connector under my dash that I think could possibly be the vats connector, also I tried disconnecting the connector and taking out the resistors and the car still started, so this means this wanst the vats wire I was looking at?
    -Thanks Alex
    Feb 2006
    2002 WS6
    My guess, is the yellow sleeve is the airbag, hence the yellow for warning. I think they even put a grey connector on the air bags. Find a wireing dyagram if you can.
    mercersburg pa
    hugger orange
    2004
    yup all manufacturers use bright plugs and yellow electrical tape to mark airbag systems
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
  1. How to Bypass your VATS
    By SandmanWs7 in forum General Help
    Last Post: 08-24-2025, 07:55 AM
  2. Vats bypass????
    By red4thgen in forum LT1
    Last Post: 08-13-2015, 02:39 AM
  3. Help With Vats Bypass
    By fasted in forum Stereo and Electronics
    Last Post: 03-03-2008, 02:53 AM
  4. vats bypass
    By formy01 in forum General Help
    Last Post: 01-18-2008, 05:51 AM
  5. doing the vats bypass on my car
    By 0rion in forum General Help
    Last Post: 08-19-2006, 07:56 PM
