Results 1 to 14 of 14
Thread: Uncorfortable with nitrous tune
08-30-2009, 04:34 PM #1
I took my car in for a nitrous tune yesterday. I'm running a 125 shot. The NA tune was at 11.5 to 1 and 25 degrees timing. The tuner changed the A/F to 12.8/1 and this was the best we got. I'm uncomfortable with how the a/f is so rich until its below the computers ability to read. I'm runnig 116 in a standalone and 125 nitrous pill with 100 fuel pill. The tuner said that if I went with a small fuel pill that the car would be too lean. So this is the best we got. I'm uncomfortable because the power is low and my graph doesn't look like anyone elses. Chime in. Give me comfort or complaints[/IMG]
08-30-2009, 05:41 PM #2
what do you have done to the car? and what kind of kit are you running dry wet or direct?
08-30-2009, 06:22 PM #3
08-31-2009, 07:23 AM #4Junior Member
- Mar 2008
- Warminster, PA
What was your bottle pressure at? Full bottle? Looks like pressure was dropping way off up top. What about timing?
Nick
08-31-2009, 10:12 AM #5
08-31-2009, 11:36 AM #6Junior Member
- Mar 2008
- Warminster, PA
What about weight?
08-31-2009, 02:36 PM #7
at the end of the run the bottle was 17 pounds with the opener bracket. I'm getting that you are suggesting that if i had more pressure, the curve would have stayed up throughout instead of falling off. I hope that thats the case. If so though, I'm still abit lean with the 100 fuel pill and the 125 nitrous pill becaust the a/f seems to be about 12.9 then it dives off at the same time that the torque dives off. I used 100 fuel pill because the 125 had me way too rich with the C16.
09-01-2009, 07:14 AM #8Junior Member
- Mar 2008
- Warminster, PA
17lbs. = empty. Fill the bottle and make sure you get right around 25-26lbs. in there w/ the bracket on (bracket weighs around a lb.). You cannot go by pressure to determine how much nitrous is in the bottle. As seen above in the dyno graph you simply do not have any liquid left in the bottle to vaporize and stabilize pressure through the run.
Here's the bad news...since this was done on an empty bottle we really don't know where your true a/f is gonna hit. So changing jetting etc. really is a guess.
Nick
09-26-2009, 06:33 AM #9
12.9 afr on nitrous may not be that lean. In all honesty a rich nitrous kit is what kills pistons. I would say you want close to the same afr on nitrous as you do N/A. I know of some guys that run leaner on nitrous and they are healthy. The thing with nitrous is it builds heat and burns faster. I will take a leaner (but clean looking plug) any day with timing being pulled as opposed to others that want a rich afr and have to run lots of timing trying to get heat in the motor.
Also 17 pounds the bottle was low. I would also tune the nitrous for about 900-950 pounds of bottle pressure. You will find that the pressure is more stable there and doesn't fall off as much during the run.Last edited by jakesz28; 09-26-2009 at 06:35 AM.
The first nitrous powered LT1 in the 8's.
8.957 @ 151.6 mph
09-26-2009, 03:06 PM #10
09-26-2009, 03:46 PM #11Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Lean is mean to a point. But I have to disagree. I would rather be richer than leaner.
Leaner can make your engine detonate.
My last engine I went way lean on a run, blew my engine.Black 1999 Blown Convertible A4
Forged 383 | ATI D-1SC
NX MAF Kit | 222/226 .585 115
AS Stage II 6.0L FI Heads
09-26-2009, 05:10 PM #12
If you’re talking about your blown combo in the sig that is a completely different engine with different needs. A rich nitrous motor will lift ring lands. This damage usually will happen with the thought of rich is safe mentality. What is usually happening with a nitrous motor is it is over timed and rich. Then when people pull fuel out the timing will cause the detonation. I sprayed 350hp on this LT1 without burning a plug tip or piston. I have been leaner then 13.1 AFR
09-26-2009, 05:47 PM #13Blown, Stroked, & Sprayed
- Aug 1999
- No Where
Nope, before the blower. I ran a 150 shot for a while.
And I kept it on the rich side. When I had it rebuilt. The builder said it was still lean.
09-26-2009, 08:08 PM #14
the power looks low to me i would think you would be mid to hi 400 rwhp. i would look for a diffret tuner.
What to look for in nitrous tune.
By RealLiveMD in forum NitrousReplies: 3Last Post: 02-11-2009, 01:32 AM -
? about nitrous tune
By 99w69kitt in forum Computer & TuningReplies: 16Last Post: 11-19-2008, 03:41 PM -
Nitrous tune without pulling timing.
By RealLiveMD in forum Computer & TuningReplies: 4Last Post: 06-20-2008, 07:05 PM -
Question: Custom nitrous tune on pcm?
By BOTLRKT in forum NitrousReplies: 11Last Post: 06-10-2008, 09:57 AM -
Lt1 Nitrous Tune
By 96lt1z28 in forum LT1Replies: 8Last Post: 09-10-2006, 08:19 PM
