02-09-2009, 04:50 PM #1
What to look for in nitrous tune.
Finally decided to take the nitrous plunge. Just wondering what should I be looking for in a so called Nitrous tune. I make 400rwhp NA I'm spraying a 100 shot. I just want to have some idea instead of going in blind as I usually do. Also, does a timing device somehow allow me to keep my NA horses or will I be forced to settle for maybe 385?
02-10-2009, 07:59 AM #2
for a 100 shot, you really need no timing pulled. factory timing is around 26-28* to begin with. if for some reason the tuner put more than that in to it, then you'll just need to back off.
02-10-2009, 03:58 PM #3
Not sure exactly what your asking for?
Are you going to tune the car yourself?
What plugs are you running?
Who's "100 shot" are you going to run?
Wet/Dry More info needed.Don't be afraid of the bottle!!! Be afraid of your tune!!!
02-11-2009, 01:32 AM #4
I'm not tuning the car myself. I'm just tryingt to gain some basic info instead of shoveling out money for something that I don't have a clue about. For example. I have a tune on my car already. I have a small cam 214/230 .600/590's 117. so not much seems to have been altered. Anyway. I've received 3 quotes. $125 from previous tuner, $300 from new shop, and $500 from guy that used to work at previous tuner's shop. Let's just say it leaves me hesitant and confused. Are they simply pulling timing which I hear can be achieved with a timing tuner? Are they pulling timing and adding fuel? Just wondering....
Also, I figured out that I should run TR6's. I'm using an ls1 plate kit wet from either HSW or NX.
I've read many posts and got different opinions. Some say I definitely will definitely need a Walbro 255 and upgraded injectors $500. Some say I need a stand alone fuel cell $700. Some say I don't need anything more than the kit and acc. I have the money for whatever nitrous related; but, given I'm doing this as a short term experiment with hopes of upgrading the motor and adding a blower in the future. I want to be as cheap but SAFE as possible. Sorry I know it's long.
Uncorfortable with nitrous tune
By RealLiveMD in forum NitrousReplies: 13Last Post: 09-26-2009, 08:08 PM -
? about nitrous tune
By 99w69kitt in forum Computer & TuningReplies: 16Last Post: 11-19-2008, 03:41 PM -
Nitrous tune without pulling timing.
By RealLiveMD in forum Computer & TuningReplies: 4Last Post: 06-20-2008, 07:05 PM -
Question: Custom nitrous tune on pcm?
By BOTLRKT in forum NitrousReplies: 11Last Post: 06-10-2008, 09:57 AM -
Lt1 Nitrous Tune
By 96lt1z28 in forum LT1Replies: 8Last Post: 09-10-2006, 08:19 PM
