Results 1 to 10 of 10
Thread: New Sparks?
    Deadwood City
    1998 Camaro Z28
    New Sparks?
    Hey whats going on, I am about to put a 125 shot of nitrous into my new 1999 z28 camaro. I was reading up on the zex website and it said something about replacing the spark plugs. So far all I have heard is that you should only replace them once you install a 150 shot! What do you guys reccomend?
    Boosted Foolz
    Buffalo
    BlAcK
    1998 FiReBiRd FoRmUlA
    i would change them to a step colder to be safe, if u run too hott u'll melt ur plugs and can cause alot of damage... better safe than soffy
    Deadwood City
    1998 Camaro Z28
    Ok yeah thats prob what I will do!
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    run NGK TR6 or champion RC9YC.
    Cocoa, Florida
    Hugger Orange
    1999 Camaro Z28
    I had my kit for months before I put it in, lots of research! I went with the NGK TR6s. What I read was that you had to swap the plugs and not use Platinum plugs as the extra heat could cause the platinum to break and create bad issues.
    Member Granatelli's Avatar
    Feb 2006
    Oxnard CA
    Yellow
    2015 Z06 Coming, 2014 Z51
    •Direct OEM replacement, exceeds OEM specifications, OBD-II computer safe
    (See application guide for over 600 fitments)
    •0 Ohm resistance
    •Patented design
    •Solid stainless connector cable with stainless snap lock spark plug connectors, unique EMI/RMI protection ring
    •The only true solid stainless steel core wire that works with today’s computer dependant engine and all race cars
    •No RFI / EMI issues – works with any fuel injection / No stereo noise
    •Increase power to the spark plug up to 400% over stock
    •Improves mileage and throttle response
    •High temperature silicone boots, 8MM jacket with fiberglass-reinforced braid resists temperatures up to 500 degrees f (1200 degree f. boots optional).
    •Ideal for use with aftermarket headers and turbocharger systems
    •Includes all necessary hardware
    Memphis TN
    Quote Originally Posted by mrr23
    +1
    Aug 2000
    Indy
    TR6 with spray seems to be the majority
    Member camaronx's Avatar
    nashville tn.
    torrid red/red interior
    2005 GTO 6spd
    I had been looking for champ #'s
    I was always wondering what the champion number was for a step colder then stock because i have had many people give me crap about ricer plugs in my american muscle but then again i am gonna use what was o0nce considered a ricer only nitrous kit---zex but now 3 outta 4 new products coming from zex are for domestic i'l remember the rc9yc's
    Feb 2006
    Oxnard CA
    Yellow
    With the Granatelli wires, you get 100% of the energy from the coil to the plug. That means it is perfect for the Nitrous application. It also allows you to run a wider gap without getting ignition/spark blow out
    While I am sure this sounds like a commercial, it does benefit you guys tremendously
    http://www.granatellimotorsports.com...connectors.htm double click on the underlined verbiage to the right that says Pull Hard
  1. Howard Morgan Case Sparks Community Outrage, Compared to Tra
    Last Post: 04-04-2012, 01:10 PM
  2. Installed Alternator Now Battery Sparks
    By wumicha in forum External Engine
    Last Post: 11-22-2011, 10:21 AM
  3. Sparks at my starter
    By Albert87 in forum External Engine
    Last Post: 12-01-2008, 04:46 PM
  4. Rapper T.I. sparks shootout in Cincinnati
    By Zboner in forum Almost Anything Goes
    Last Post: 05-07-2006, 05:01 PM
