Results 1 to 3 of 3
Thread: Sparks at my starter
11-26-2008, 02:42 PM #1
The other night I tried starting up my 95 trans am and it wouldn't start,so I opened my hood and there was sparks coming from my starter and then the car wouldn't even crank over anymore
11-26-2008, 04:17 PM #2
Check to ensure all you wires are tight at the starter. If they are also inspect them for cracks or missing insulation. Chances are you blew a few when it was arching so also check those.
12-01-2008, 04:46 PM #3Junior Member
- Severna Park, MD
Fuselink?
If it dosn't start after tightening the connections check the fuse link from the starter solenoid to the alternator (if it is distorted from heat you must replace/splice). You could have blown the fuse link by grounding (sparks). The fuse link is a glorified way to say reduction in wire size from the alternator (usually 10 gage) to the starter solenoid (usually 12 gauge).
Howard Morgan Case Sparks Community Outrage, Compared to Tra
By Ed Blown Vert in forum Gun's & AmmoReplies: 0Last Post: 04-04-2012, 01:10 PM -
Installed Alternator Now Battery Sparks
By wumicha in forum External EngineReplies: 7Last Post: 11-22-2011, 10:21 AM -
Starter Going Bad.. HELP
By LS1_WS6_TransAm in forum Firebird / WS6Replies: 2Last Post: 01-14-2007, 11:51 PM -
Rapper T.I. sparks shootout in Cincinnati
By Zboner in forum Almost Anything GoesReplies: 21Last Post: 05-07-2006, 05:01 PM -
New Sparks?
By LS1King in forum NitrousReplies: 9Last Post: 03-13-2006, 12:10 PM
