Results 1 to 16 of 16
    Junior Member supersexy's Avatar
    FT. Bragg, NC
    02 SS
    A little pissed off
    Well I just recently had a cam installed along with a 2800 stall and a shift kit as well as some other mods. I've been taking it easy on it for the last 2 weeks because I haven't had the WOT dyno tune yet. Well to make a long story short I took it out today after having it put on the dyno. I raped it a couple times. Nothing from a dig, and I slow down to turn around. At this point I'm done playing and driving casually. When it shifted from 1st to 2nd it sounded like a sledgehammer hitting underneath my car. I tried it again to the same damn sound.
    So I put it in 2nd and crawled home. I jacked it up and nothing is leaking, but there is a little play in the driveshaft. There is also some weird sound from the rearend and the trans when i rotated the driveshaft. All in all I think I'm fucked, but there is no tellin. Do any of you guys or gals have any suggestions? I also forgot the numbers on the dyno were 383HP 350TQ. This was with 101 degree temps and 45% humidity. Do you guys think these are good #'s?
    02 SS, Cammed and other shit!!!
    2000 Camaro B4C
    the numbers are pretty damn good, could it be your y-pipe hitting your floorboards...just a thought
    2000 B4C Special Service Package Z28 - Kooks 1&7/8 Stepped 2'' - TSP Torquer V.2 - FAST 92/92 - BDR 4000 Conveter - Xtreme Trans Stage II - Full UMI Suspension - Pacesetter LT's - Comp Drag Shocks - Magnaflow - Cutout - ZO6 MAF - FTP LID - Street Tuned -
    2000 Camaro B4C
    what cam btw
    FT. Bragg, NC
    02 SS
    It's a custom grind Comp Cam. 228/230 585/585 114 LSA. Now I'm not 100% sure on the grind because I forgot to get the build sheet from the shop. But I will be taking care of that on Monday.
    Member fergyflyer's Avatar
    Sep 2008
    Eustis, Fl
    2002 Z28
    Look for a broken motor mount.
    The transmission and the rear end are not the quietest things when you put it in nuetral and turn stuff.
    Member c5z28's Avatar
    Bay Area
    On your ass flashing
    my highbeams
    I doubt that this is it-but when cleaning the maf I unplugged the iat finished what I did etc. Never plugged it back in and the shifts were rough as hell(metal on metal) Plugged it back in everything was cool. Just an idea.
    FT. Bragg, NC
    02 SS
    Thanks guys for the input. I'm about to crawl underneath the car again. I'll keep ya posted!
    Import Killer SLP00blueSS's Avatar
    MIchigan
    how about a trans mount?
    FT. Bragg, NC
    02 SS
    Hey guys I found it. The 15mm torque arm nut loosened and fell off and the bolt backed out. This allowed the axle to rotate up and down slamming the torque arm against the trans tunnel. It's all good. I finally fixed and I'm givin' it hell again!
    Coral Springs, Fl
    Sunset Orange Metalic
    Quote Originally Posted by supersexy View Post
    Glad to hear
    good luck with the new setup
    hello blindboy2k1's Avatar
    pittsburg,CA
    i had the same problem with that stupid nut backing out , it happend to me 2 times , my solution was buying energy bushings and welding the mount together where it slips open , never had a problem since
    FT. Bragg, NC
    02 SS
    Yeah I got to get back underneath and see if anything is backing off. I'm also going to put a shit-load of loctite on it so this doesn't happen again. How well do you guys think my rear end and tranny are going to hold up to the newfound power? I have a tranny cooler now so overheating shouldn't be an issue.
    FT. Bragg, NC
    02 SS
    I was also wondering if you guys could give me ballpark estimates on what times I would post in the quarter? I've been told from the shop I go to that if I tree it pretty good I could probably get a low 12.
    Coral Springs, Fl
    I could see mid 12s and possibly low 12s depending on your launch
    Let me know how you like the stall
    Junior Member kibz28's Avatar
    Aug 2009
    pa
    2002 Z28
    haha the same thing happend to me already, and if u plan on using good tires plan on a good rear unless u already have one
    FT. Bragg, NC
    02 SS
    I've been taking it a little easy on it lately cause I'm not financially ready for the rear end to go out.
  1. Im So Pissed
    By bertt23 in forum Texas Members
    Last Post: 07-25-2008, 02:52 PM
  2. just pissed off.....
    By pewterzron in forum Almost Anything Goes
    Last Post: 01-15-2008, 03:50 PM
  3. so pissed right now
    By issues in forum Corvette
    Last Post: 11-10-2007, 08:03 PM
  4. Im So Pissed!!!!!!
    By camarostripes96 in forum LT1
    Last Post: 10-02-2007, 06:45 PM
  5. Pissed Off!!!!!
    By LETHALxLS1 in forum Almost Anything Goes
    Last Post: 02-04-2007, 06:36 AM
