Thread: Frost....MAP sensor question
08-04-2009, 07:19 PM #1
I think I understand the map sensor linear table or at least the theory behind it. It's to scale your map sensor from 0-5v correct? So on 2 bar I see people using 200,207, and a couple other values but wouldn't it be 210 since that's where the ve maxes out on 2 bar?
What I don't understand is why there would be an offset and how to determine what your offset is? Is that key on/engine off scanner logging the map in kpa? I just assumed that would always be zero right, because the map should be reading zero there right?
08-04-2009, 09:20 PM #2
nevermind...did some reading and have some of it figured out.
Offset is the 0 volt reading of your map sensor
and the linear is the 5v reading minus the offset.
What if you don't know these values? What do you use then?
08-05-2009, 08:05 AM #3
If you don't know them, you figure out the offset... key-on with an OEM MAP and write down the value from the scanner. GO back to the 2bar MAP and adjust the offset until you read the same value at key-on.
Linear is the effective range of the sensor.
What is the part number that you have?
08-05-2009, 07:38 PM #4
08-05-2009, 09:43 PM #5
offset = 8 (should get you very close)
linear = 200
That part number has now been superseded by 12615136.
Question for Frost...
By TACGNOL in forum Computer & TuningReplies: 5Last Post: 04-16-2010, 04:49 PM -
Question: Question Frost?
By blackSS01 in forum Computer & TuningReplies: 7Last Post: 03-05-2010, 04:56 PM -
Frost...spark related question
By 0rion in forum Computer & TuningReplies: 7Last Post: 08-13-2009, 07:27 PM -
another question for frost
By BMJ99Z28 in forum Computer & TuningReplies: 7Last Post: 07-09-2009, 01:08 PM -
By guitarjay76 in forum Computer & TuningReplies: 10Last Post: 06-07-2009, 09:12 AM
