Results 1 to 11 of 11
    Feb 2007
    onaway,MI
    2000 Z28
    Question for Frost...
    I programmed my car with a Hypertech III. When I pulled the battery, it reset to stock settings. When you do the tunes, does that happen, or does it stay permanently? This may be a stupid questoin...I just don't know how it works.
    Junior Member mynumber1hater's Avatar
    Apr 2009
    dayton, tx
    98 Z28
    Quote Originally Posted by guitarjay76 View Post
    It has always been my under standing that the hypertech pulls your stock tune and installs its own new tune.. So pulling the battery should do nothing. But frost would know for sure.
    Feb 2007
    onaway,MI
    2000 Z28
    From what Jeg's tells me this is common with any handheld programmer because once the battery is pulled it erases the codes that were put in because its only in the temporary memory, not actually burned into it. I was just wondering how the tunes Frost does work. Hypertech told me I can send my tuner back and they'll reset it, but in order to use it again, I'll have to have a dealer reflash my computer and start all over again. A more permanent tune would be better, because then I won't have to worry about it if the battery goes dead or something.
    Apr 2009
    dayton, tx
    98 Z28
    His are PERMANENT.....
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    All tunes hypertec and other wise are permanent unless reflashed. The only thing being clear at battery disconnection are DTCs, fuel, and air trim learning.
    My mail order tuning would likely suffer dollar-wise if PCMs 'lost' their tunes on the way to the customer
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Apr 2009
    dayton, tx
    98 Z28
    X2
    corry, pa
    2002 ss camaro
    I am wondering what route to take for a tune, my 02 ss 6speed, dynomax bullit, no cats, slp lid, k&n filter, 160 thermostat. I was curious if handhelds are worth the money spent for the power gains, i dont really want the down time of sending my computer away. Any suggestions guys? Thanks Gregg
    what are your future plans for the car? If you have plans to mod further I'd probably wait until then to do the tune. I notice you have a 160 stat so are your fan settings still at stock? If so the stat really isn't doing much for you at the moment.
    You have a few options as far as your tune. You can find a local dyno tuner and get it tuned that way.....you could buy a handheld.....or the cheapest way is to do a mail order tune through Frost. I believe he's still doing tunes for $125. Someone that's had one can chime in but I think his turn around time is very quick. I think he basically mails them back out the same day he gets them so you're just looking at mail travel time.
    corry, pa
    2002 ss camaro
    thanks for the input, my fan settings are still the same, i need to get that changed def, is getting a tune the only way to change the settings for the fans?
    Richmond VA
    LS1.com Sponsor
    GM Tuner
    Fan settings can be changed with the handheld units as well as custom tuning.
    Let me know if you have any questions.
  1. Question for Frost...
    By TACGNOL in forum Computer & Tuning
    Last Post: 04-16-2010, 04:49 PM
  2. Question: Question Frost?
    By blackSS01 in forum Computer & Tuning
    Last Post: 03-05-2010, 04:56 PM
  3. Frost...spark related question
    By 0rion in forum Computer & Tuning
    Last Post: 08-13-2009, 07:27 PM
  4. Frost....MAP sensor question
    Last Post: 08-05-2009, 09:43 PM
  5. another question for frost
    By BMJ99Z28 in forum Computer & Tuning
    Last Post: 07-09-2009, 01:08 PM
