Results 1 to 20 of 24
Thread: 98-02 birds
07-27-2009, 02:26 PM #1
98-02 birds
Is there anyway to tell the ws6 cars apart by looking at the exterior only?
07-27-2009, 03:44 PM #2
A little by collors and I think theres different wheels for a few years. The 98 WS6 has one exuast, umm pretty much all I can think of at the moment.
07-27-2009, 04:36 PM #3Custom Painter/Tech
- May 2009
- Plainwell, Mi
Flame Red / Orange Custom- 1998 Trans Am
98 Trans Am Custom Paint, Ghost Skuls On Racing Stripe + Custom Front Lip, :MODs Tubular K-member, Tubular Upper and lower A-arms, Tubular Control Arms, 4:10's, Cam L-.567/.575 [email protected]/.218,1.85 Roller Rockers, P&P Heads, ARH Headers & HF Cats & Y-Pipe, SLP loudmouth catback, +'s
07-27-2009, 05:00 PM #4
07-27-2009, 05:32 PM #5
07-27-2009, 11:40 PM #6
Hood would really be the best way or the ws.6 emblem on the back?
Some of them will have a ws.6 in a circular plate in the middle of the wheel, but some have the ABS.
A lot of times you will see a T/A with an aftermarket ram air hood, but no emblem on the back. So its a clone
07-28-2009, 01:15 AM #7Junior Member
- Mar 2007
- Kansas~
Sunset Orange Metallic- 2001 Trans Am WS6
The only way i can think of is the Late 01's and all 02's (except the 35th annivs) had a different style 17" rim. Also, the late 01's and 02's didn't have WS6 center caps. They had pontiac logos...i could be mistaken on this, but i'm pretty sure that's the case.
98-early 01 style -- http://www.ls1.com/forums/album.php?...&pictureid=882
http://www.ls1.com/forums/album.php?...pictureid=1090
Late 01/02 style -- http://www.ls1.com/forums/album.php?...pictureid=1198
http://www.ls1.com/forums/album.php?...&pictureid=990
Hope this helps
07-28-2009, 09:24 AM #8
There is no absolute, for certain, way to tell if it is a true WS6 or not by looking at the exterior. Sure there are obvious things like the hood, or the emblem out back, or the wheels, or the exhaust, but all of these things can be modifications done to any car to make it appear to be a WS6.
You could look at the build numbers. Of course this is on the inside of the door. And that is assuming that someone didn't replace the sticker.
So, as far as I know, the only absolute way is to look up the VIN.
07-28-2009, 10:56 AM #9Firebird Encyclopedia
- Oct 2006
- St. Clair Shores. Michigan
Too bad because it's actually the best flowing of all the Factory exhaust systems.
As for the OP question,
The Best way is to look at the RPO sticker inside the Drivers door. If the sticker is missing then the Vin can be run at a dealer to come up with the RPO list for that car.
If the WS6 RPO is not present then it's NOT a WS6Craig
Semi Retired Street Racer
Gone but not forgoten
NBM `98 Formula M6 HdTp
1 of 1 Build Date 3/12/98
07-28-2009, 01:24 PM #10Junior Member
- Apr 2007
- Indianapolis, IN, USA
Red- 1998 WS6 Trans Am
my 98 ws6 still has original single exhaust
lots of people tell me I should change it but I can't be bothered to really. I don't see the back end often even with it being my daily driver and also, it still sounds nice
07-29-2009, 06:34 AM #11
07-29-2009, 07:05 AM #12Orig Regist: 9/98
- Sep 2005
- NE Indiana
Black- 1998 Trans Am WS6 'Vert
Even rims can be changed, more easily than adding a hood.
9T8W66 is correct, the ONLY way to guarantee it is the WS6 RPO on the door sticker, or running the VIN through the dealership's computer to obtain the RPO listing for the car. The VIN alone does NOT indicate the car has the WS6 option. Nor is there anything special about the rear gears on WS6s, only that WS6s w/ A4 required the optional 3.23 gears as a "mandatory option". Thus, no A4 WS6 w/ 2.73 gears, but 3.23 gears is no guarantee you have a WS6 as it was optional on non-WS6/SS A4 V8 f-bods.
I'm glad nobody asked about that WS6 spoiler either.
On the '98 SOTL exhaust, new noise rules went into effect in '99 and required a quieter exhaust than was put on the '98 SS/WS6 cars. The SOTL is a better flowing and better sounding exhaust than the '99+ SS/WS6 exhaust systems. There have been several dyno tests over the years that shows that the addition of an aftermarket cat-back picks up more power on a '99+ SS/WS6 car than that same exhaust on a '98 SOTL car, which indicates the '98 SOTL to be a slightly better flowing system than the '99+ SS/WS6 exhaust. The only difference between the two is the muffler and tail-pipes (single 3.5" vs dual 2.5"). Theres less turbulence in the muffler of the SOTL system since it flows in on one side and out the other rather than making a 180-deg turn to go back out the passenger side.
I'm sure all the flack GM took on the "ricer" exhaust on the '98s also had something to do w/ going to a dual-out setup in '99. Personally, I still have my SOTL. The fact that, until you go w/ headers and a ORY, there is little to be gained by changing the SOTL to an aftermarket cat-back, and the fact that it sounds pretty good, I've elected to retain that stock, albeit lop-sided, appearance of the SOTL. Any chuckles I get are quickly drowned out.
Johnny B - '98 "Triple Black" WS6 Convert, M6, All Options, ASC #3030 (1 of 50)
KBDDSFC, DGM C/F Tonneau, MTI C/F Lid, K&N, HPP-III, 160 T-stat, Pro 5.0
Link to Firebird Production Breakdowns
07-30-2009, 07:49 AM #13
What was the purpose of having two cats and a y pipe? You would think they would have done true duals from the factory.
07-30-2009, 08:15 AM #14
07-30-2009, 08:43 AM #15
I agree with what most say here. Check the door for the RPO code. Because looks can be changed.
NOT A WS6
07-30-2009, 09:20 AM #16
Don't know about '98, but from 1999 on, weren't at least some of the WS6 cars given square exhaust pipes and all the regular Trans Ams round ones?
07-30-2009, 09:23 AM #17
07-30-2009, 10:55 AM #18Firebird Encyclopedia
- Oct 2006
1998-2002 Standard cars have Aluminum Oval exhaust tips (same tips as `96-97 WS6)
All `99 -up WS6's have 2.5" Polished round tips `98's have the Single Polished 3.5" tip.
07-30-2009, 01:21 PM #19
if your looking at the interior open the drivers door and look for the ws6 code in the door jam thats the only way youll ever know the ws6 was $3100 option that upgraded suspension and added ram air hood and 17in wheels so im sure you wont see a difference in the interior
07-31-2009, 11:49 AM #20
NBM Birds Unite!
By Zaccagnini in forum Firebird / WS6Replies: 84Last Post: 10-26-2012, 05:38 PM -
Anyone here have birds?
By DrMilhouse in forum Almost Anything GoesReplies: 5Last Post: 12-26-2009, 04:55 PM -
any third gens birds...?
By tpibird923 in forum Firebird / WS6Replies: 12Last Post: 12-21-2009, 08:08 AM -
Panel Birds
By JoshieDoom in forum Appearance SectionReplies: 5Last Post: 12-21-2007, 08:48 PM -
anyone own pet birds?
By 94z28l in forum Almost Anything GoesReplies: 23Last Post: 09-20-2007, 03:37 AM
