Results 1 to 10 of 10
    LSwut tep98ws6's Avatar
    Jun 2009
    Saint Louis, MO
    Arctic White & Black
    '98 WS6 M6 - SWAPTIME!
    ABS INOP light on
    I just put new front calipers and pads on after they were all jacked up, flushed the brake fluid and now my ABS INOP light is on. Im not quite sure why its on ... Any ideas? Im going for my inspections Wednesday... Eek
    Member zmg00camaross's Avatar
    missouri
    pewter
    2000 camaro ss
    May need the abs system bleed, or you jack up a sensor while installing brakes, well need to pull codes and post up
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    ABS light is on with mine as well. A conventional scanner wont work, must have something that will scan the BCM.
    2000 Camaro B4C
    my ABS INOP code has never stopped mine from passing inspection
    Jun 2009
    Saint Louis, MO
    I tried pulling codes, have nothing (which is good because before I started working on it, I had four PCM codes!!!!!!!!!!!!!) but none the less, no ABS codes. I'm fairly sure it's just a wiring issue ... I had both front brakes off (did calipers/pads/rotors), battery and alternator out while doing a plethora of work to my TA. At least my fingers are crossed it's a wire issue. I also went to replace my LR E-brake and it didn't correct my issue there, although it did make the lever seem tighter but I think I need new e-brake shoes.
    In MO it normally wouldn't pose a problem for an ABS light on but my car is on a "rebuilt" title from Oklahoma so they're going to nitpick everything since I have to get both state/emissions plus a structural inspection at the highway patrol. Thus far, I've had to put in a new steering rack, new tie rod ends, all new brakes all around (including the front calipers), new o2 sensor, new e-brake cable ... it's been a pain, but none the less, I love her still
    Junior Member goose's Avatar
    Mar 2009
    Schaumburg ILLINOIS
    SOM WS6
    2002
    I had this problem for about a year no ABS or TCS, the lights would come on and then go off. I changed the wheel hubs rotors calipars this did not solve the problem.
    I took it to have the brake fluid changed and the mech ask if he could scan for any codes I told him to go ahead but he may not be able to find any. No codes came up so he check the harness with a volt meter and that's when he found the problem.
    Come to find out the harness from the right front speed sensor had two broken wires. The dealer had the harness on back order the cost was about 60.00. The mech fixed the broken wires and alll was good again.
    unplug and replug in the sensors... on each brake...
    Jun 2009
    Saint Louis, MO
    im going to try that tonight if it ever stops monsooning out
    ps, speaking of brakes... has anyone ever had any issues with their parking brake? i just changed out my cables and still, no brake. the shoes look good and is there any way to adjust the brake? i park on a hill quite often and i'd hate to take out a few cars with my pretty TA because of no parking brake and popping out of gear :-| !!!!!!!!!
    hmm... never had that happen... sounds like it isn't conected some where...
    missouri
    pewter
    2000 camaro ss
    U can adjust it, it's just like a drum brake set up. There is the adjuster you just use a screwdriver and adjust to push the shoes out
  1. Help: abs inop light and car service light
    By hellskull in forum General Help
    Last Post: 03-07-2015, 04:34 AM
  2. Help: ABS/INOP light on
    By 98maro in forum General Help
    Last Post: 11-07-2013, 03:47 PM
  3. Help: abs inop and tcs light is lit on my ws6.
    By juvie909 in forum Firebird / WS6
    Last Post: 05-10-2009, 12:27 AM
  4. abs inop light
    By Ls1_385hp_T/A in forum General Help
    Last Post: 08-30-2008, 08:44 AM
  5. Abs inop and asr light
    By paul1299 in forum General Help
    Last Post: 07-14-2008, 01:56 PM
