    Junior Member juvie909's Avatar
    Apr 2009
    ca
    Candy Tangerine
    2000 WS6
    Unhappy abs inop and tcs light is lit on my ws6.
    Someone please help. i was wondering if anyone has experienced this problem. while driving the tcs off light and abs inop light will come on. Sometimes it will say low traction then the other two lights will come on someone help.
    Feb 2006
    2002 WS6
    sounds like you have a bad wheel speed sensor some where or a dirty reluctor ring.
    Give me a place to stand. levityinc3's Avatar
    Jacksonville, FL
    2000 SS '89 IROC-Z
    Same problem here. I pulled off all my wheels and cleaned the ABS sensors located on the back of the calipers. My ABS light still comes on, but it may be because a couple of my LEDs are burnt out in my center brake light.
    Junior Member goose's Avatar
    Mar 2009
    Schaumburg ILLINOIS
    SOM WS6
    2002
    Hi all new here. I just had this problem fixed. My right front speed sensor harness had two broken wires I had the wires fixed and the codes removed and all has been good for the last two weeks. I still will buy a new harness the cost was about 65.00 from the dealer. I had this problem for about a year. I changed hubs calipers rotors pads and this did not fix the problem. Have some one with a volt meter check the wires. That's how the shop I took it to found the problem.
    John
    Apr 2009
    ca
    Candy Tangerine
    2000 WS6
    thanks to all goos information. so the spees sensor is locates on the caliper
  1. Help: abs inop light and car service light
    By hellskull in forum General Help
    Last Post: 03-07-2015, 04:34 AM
  2. Help: ABS/INOP light on
    By 98maro in forum General Help
    Last Post: 11-07-2013, 03:47 PM
  3. abs inop light
    By Ls1_385hp_T/A in forum General Help
    Last Post: 08-30-2008, 08:44 AM
  4. Abs inop and asr light
    By paul1299 in forum General Help
    Last Post: 07-14-2008, 01:56 PM
  5. Abs/inop Light?
    By StoreKeeper99Z28 in forum Western Members
    Last Post: 05-28-2007, 09:01 AM
