Results 1 to 13 of 13
Thread: Rear window defog
07-19-2009, 04:14 PM #1Member
- Dec 2006
- Warren, Ohio
Navy Blue Metallic- 2002 Camaro SS
Rear window defog
Went to turn on the rear window defog last night....nothing...Fuse is good, connections on rear window are good. I push the button in and nothing no light and no defog. Anyone else have this problem? And how did you solve it?
A new switch or relay and how hard is it to change? Thanks in advance..
07-19-2009, 04:18 PM #2Impounded
- Oct 2007
- Beaver Dam KY
Supposed to be a relay behind the dash somewhere. Do your power seats work as well?
07-19-2009, 04:42 PM #3Member
- Dec 2006
- Warren, Ohio
Yea, my power seat works great.
07-19-2009, 04:45 PM #4Impounded
- Oct 2007
- Beaver Dam KY
07-19-2009, 04:49 PM #5Member
- Dec 2006
- Warren, Ohio
Thanks Joshiedoom I guess I will have to just start taking things apart.
07-19-2009, 04:50 PM #6Impounded
- Oct 2007
- Beaver Dam KY
07-19-2009, 04:56 PM #7Member
- Dec 2006
- Warren, Ohio
I will double check all that. Have you changed one?
07-19-2009, 05:03 PM #8Impounded
- Oct 2007
- Beaver Dam KY
07-19-2009, 05:08 PM #9Member
- Dec 2006
- Warren, Ohio
Where is the relay located just incase I run into that problem
07-19-2009, 05:10 PM #10Impounded
- Oct 2007
- Beaver Dam KY
07-19-2009, 05:13 PM #11Member
- Dec 2006
- Warren, Ohio
Thanks I could use all the help I can get.
07-19-2009, 05:24 PM #12Impounded
- Oct 2007
- Beaver Dam KY
07-19-2009, 05:28 PM #13Member
- Dec 2006
- Warren, Ohio
Thanks again for the diagram
Help: rear window ? s
By knightshade0 in forum Appearance SectionReplies: 3Last Post: 11-24-2013, 09:42 AM -
rear window froster ? wire on the rear window
By twozs in forum General HelpReplies: 3Last Post: 07-18-2012, 08:32 AM -
C5-R rear window
By lingenfelter69 in forum CorvetteReplies: 14Last Post: 06-22-2011, 02:07 PM -
Relay for rear defog?
By Freebs in forum General HelpReplies: 2Last Post: 12-30-2008, 08:52 PM -
anyone had there rear window out?
By toplessHO in forum ConvertibleReplies: 7Last Post: 07-15-2006, 04:13 AM
