Thread: posi rear
    now greybat66
    bloomfield nj
    1998 trans am
    posi rear
    do all 1998 trans am come with posi rears? thank you.
    Beaver Dam KY
    79 T/A -91 Firebird
    1998 Trans Am -Oynx Black
    Quote Originally Posted by purplebat66 View Post
    Yep.
    Should be an auburn with yellow springs.
    If your having posi issues, then swap out the fluid/ add limited slip additive and try it out.
    Or live with a 1 wheel peeler till you upgrade like me
    now greybat66
    bloomfield nj
    1998 trans am
    no its fine i was just curious and thank you so much.
    Member 99'CajunFirehawk157's Avatar
    39466 USA
    Bright Red
    99 Firehawk #157 Roadster
    Make sure if its an auburn unit do not put any synthetic fluid just dyno and for me 2 bottles of gm posi additive works best, IMHO.
    Beaver Dam KY
    79 T/A -91 Firebird
    Quote Originally Posted by 99'CajunFirehawk157 View Post
    Make sure if its an auburn unit do not put any synthetic fluid just dino and for me 2 bottles of gm posi additive works best, IMHO.
    Why only dino???
    39466 USA
    Bright Red
    Why only dino???
    Dunno, ask Auburn, something about the material they use, brass or bronze and compatibility issues...
    from the web:
    What kind of oil and additive should be used with an Auburn Performance Differential?It is important when installing
    an Auburn High Performance, Pro Series or ECTED® LOCKER that a high quality non-synthetic 80W90 GL-5 gear oil
    be used. Treat the oil with Auburn Gear, GM or Ford friction additive. Three ounces of additive treats one quart of oil.
    Friction additive part numbers:
    Auburn Gear: 504102
    GM: 1052358
    Ford: C8A219B546A
    Regards,
    Todd
    #cajunhotrodder on instagram
    Beaver Dam KY
    79 T/A -91 Firebird
    from the web:
    Good info.
    Mine has synthetic in it..., and it does 1 wheel peels...
  1. New posi rear end help
    By Sarge91 in forum Drivetrain
    Last Post: 09-03-2010, 08:20 AM
  2. Question: Posi Rear
    By Motomas in forum Firebird / WS6
    Last Post: 07-13-2009, 01:38 PM
  3. Who`s Rear posi is Better ?
    By 99CANADAHAWK in forum Drivetrain
    Last Post: 05-18-2008, 05:13 AM
  4. ? about lt1 posi on a ls1 rear housing
    By FORMULA7 in forum Drivetrain
    Last Post: 02-25-2008, 07:13 PM
  5. Rear end's posi is over..
    By AKIRA in forum Drivetrain
    Last Post: 02-02-2007, 04:03 PM
