Thread: Door tweeter removal?
07-11-2009, 06:47 AM #1
How the hell do you get the little metal clips off that hold the tweeter in without breaking off the plastic piece?
07-12-2009, 06:01 AM #2
Has no one figures it out?
1998 ws6 T/A door tweeter.
07-12-2009, 01:27 PM #3
When I replaced my door speakers with componets, I had to remove those plastic peices for the new tweeters to fit, good thing cause the first one I tried broke anyways.
Might try asking a car audio shop or the stealership, I'm assuming your trying to put factory speakers back in.
07-13-2009, 04:12 AM #4
I am replacing the factory speakers with CL-61CV from Kee audio.
When you removed your old tweeters how where they mounted in the hole-screws,clips,etc.
07-13-2009, 04:46 PM #5
My factories had the little metal clips, I put alpines in cant remember the exact model. I'm assuming most aftermarkets mount the same way, you don't need the clips. Mine went into the factory holes, then a threaded trim ring on the outside to hold them in. Just a little sanding/utility knife since the factory holes were not quite round.
07-14-2009, 06:17 AM #6
oh, so I have not look at how the new ones mount.
So imay not need the clamps.Good.
I purchased new factory tweeter a year or so ago and that's when I could not get the clips off in fear of not being able to remount factory ones.
Thanks
07-31-2009, 10:51 AM #7Member
- Feb 2007
- austin
Black/Black- '00 Firebird WS6 T/A
yeah just any ole way to stick 'em in there works fine. i just yanked the factory metal shit out and glued directly to the grille. then i blew the tweeter and the replacements are on the way... will have to see about getting them put in properly but no doubts it'll be aight.
07-31-2009, 09:19 PM #8
when i did mine, i pulled metal and all out with stockers. My A/D/S tweeters happened to sit perfectly in the stock grill holes using the flush mount bracket. i was able to glue that to the door panel. Looked stock. the tweets had grills incorporated so no reason to try and fit stock grill back over them.
Replacement Tweeter grill/cover, pass door 99 T/A
By 99RedTa6spd in forum Appearance SectionReplies: 1Last Post: 07-26-2011, 12:07 PM -
Where can I get replacement tweeter cover/grill RF door
By 99RedTa6spd in forum Firebird / WS6Replies: 1Last Post: 07-26-2011, 08:29 AM -
02 Silverado door lock removal
By c5z28 in forum GM TrucksReplies: 4Last Post: 03-15-2011, 01:25 PM -
Help: Door panel removal
By davidz28 in forum Camaro / SSReplies: 6Last Post: 02-14-2011, 05:53 PM -
Help: GTO door panel removal
By John Carlson in forum GTOReplies: 4Last Post: 07-12-2009, 03:35 PM
