Results 1 to 2 of 2
    Sunny L.A.
    Med. Dark Purple Metallic
    1995
    LS-2 & LS-6 swap info...
    I'm new here, and did a quick search, and I know this must be discussed every once and a while somewhere here, but I haven't seen it.
    I haven't been into yanking an engine apart for a long time ---but I've done a few swaps and like the idea of a "simple' replacement -- using factory parts if possible, including the factory computer set-up. So what I want to know is, what's involved with an LS-2 or LS-6 (if that's what they're still calling the newest ZO-6 engine...) in an LT-1 or LS-1 F-body? Does the GTO use the electronic throttle, and if so, could it be converted for installation into an F-body.... or could an f-body be converted to the throttle-by-wire? If so, why couldn't an LS-2 GTO computer simply be swapped with the engine into an f-body? They are close in weight and tire diameter...
    Thanks in advance for any info you can give on this, and if I can REALLY get almost the same horsepower in an LS-1 by using simple bolt-ons that won't reduce durability (like superchargers can), please let me know that as well.
    Senior Member Redphoenix1998's Avatar
    Apr 2002
    San Jose
    1998 Pontiac Trans Am
    In an LT1, there will be some required mods required like a new ECU and wiring harness but as far as I know, dropping an LS1 should be pretty straightforward. as far as the LS2 motor, Harness and ecu because of the repositioning of the cam positioning sensor and knock sensor. As far the the throttle by wire, it's possible, I don't know of anyone who has done it. Most people just use a 90 mm TB from FAST to fit the LS2 manifold and still run the cable wire system. The Electronic Throttle Body would require you to swap out the accelerator assembly
  1. Anyone have info on an ls6 swap with a 4l60e
    By redbird555 in forum Internal Engine
    Last Post: 03-17-2011, 08:23 AM
  2. Question: a4 to t56 swap almost done need info!
    By nerisls1 in forum Manual Transmission
    Last Post: 03-22-2009, 04:41 PM
  3. Need Some Info On Ls1 To Ls7 Swap
    By somws602 in forum General Help
    Last Post: 06-25-2008, 04:08 PM
  4. 5.3 van ls1? Swap info???
    By 64ls1chevelle in forum General Help
    Last Post: 06-20-2008, 01:57 PM
