03-21-2009, 03:03 AM #1Junior Member
- philly
white- 1998 z28
a4 to t56 swap almost done need info!
I have a 98 z28 that was an 4l60e trans that broke completely so i have a
t56 that is already in holes cut for master and shifter everything in except mufflers and sterring colum and center console the only problem is the reverse lockout
i can't seem to find an answer for making the reverse lockout work with the comupter on a 98 been searching everywhere if anybody knows please let me know thanks
98 ls1 z
stock few mods
8.5 mm wires
k$n filter
slp lid
light tune
many mods to come soon...
03-21-2009, 03:15 AM #2
on my t56 swap i didnt use the reverse lockout. trans still goes into reverse.
did youinstall the support plate for the Slave? if not your firewall will flex badly!!!
03-21-2009, 05:03 PM #3Junior Member
- philly
white- 1998 z28
it was a pain but i did install it and have no flex the only thing i hear is a little throught bearing i think but i know everything is in right also i put four quarts of royal hope that was enough got to check it again
03-22-2009, 01:21 AM #4
03-22-2009, 05:59 AM #5
03-22-2009, 06:37 AM #6Junior Member
- philly
white- 1998 z28
no you dont understand the whole swap was a pain and the master was pita but i dont know what plate hes talking about..... is it the little plate above the pedal like a 90 degree plate i have no clue all well so be it i ll be doing some fab work then
03-22-2009, 04:41 PM #7
Ok, I miss understood. Sorry Quik.
Anyone have info on an ls6 swap with a 4l60e
By redbird555 in forum Internal EngineReplies: 26Last Post: 03-17-2011, 08:23 AM -
Need Some Info On Ls1 To Ls7 Swap
By somws602 in forum General HelpReplies: 6Last Post: 06-25-2008, 04:08 PM -
5.3 van ls1? Swap info???
By 64ls1chevelle in forum General HelpReplies: 3Last Post: 06-20-2008, 01:57 PM -
LS-2 & LS-6 swap info...
By F-body fan in forum General HelpReplies: 1Last Post: 01-31-2006, 08:00 PM
