Results 1 to 13 of 13
    Junior Member CamaroSS354's Avatar
    Jun 2009
    Columbia, SC
    2002 Monte Carlo SS
    2002 Camaro SS Concern
    ok, i'm a huge camaro fan just like everyone on this forum so i know quite a bit about them but i'm not an expert. i plan on buyin an 02 SS by next summer and i was wonderin if there were anything i need to know about them. for example, what are some things i need to lookout for on the car before i buy one, pros, cons, etc... thanks for any help!
    Member luvmyz28's Avatar
    Feb 2007
    Council Bluffs IA
    nbm
    99 z28
    well the only thing I can say right off would be to just take a look at all the different areas on this site. alot of helpful threads in here. the only stuff that comes to mind would be that the rear ends on these cars (meaning the98-02 ta and camaros ls1s) are weak. so listen for the whining growling sounds from it or take a peek under to see if there is any heavy leakage. grab the driveshaft at the rear and give it a shake to check for play in the bearing. roof bubbles are common as well. from what I hear it has to do with the glue used for the tops. thats only cosmetic though. thats all I got right now. just do the usual checks for anything else like previous body damage or mechanical type stuff.
    Mar 2009
    Arizona
    2002 SS Camaro
    Quote Originally Posted by luvmyz28 View Post
    All very true
    Member Baluchitherium's Avatar
    It has a big wing!
    Yeah man.. good info given.
    Let me say first that I love these cars but like many vehicles they do have a decent list of problems that plague them.
    Weak spots I have noticed:
    Rear ends
    Bad window motors
    Hydraulic systems on the M6 (six speed manuals)
    Every F-Body I have had has ALWAYS had AC problems
    Headlight motors on Firebirds
    Leaky T-Tops on some
    VATS system seems to crap out alot (the little key security thing )
    Fuel pumps seem weak on these cars.
    Dash Cracks
    Many LS1's seem to burn oil between changes
    Warped rotors seem to plague these cars. My trick is to torque the lugs evenly with a torque wrench whenever reinstalling your wheels...Haven't had a problem since.
    And I have seen quite a bit of alts,cat converters going out on these cars...
    The good side:
    My car is going on 140K + on original motor,tranny and doesn't burn any oil between changes.
    Pulls very strong,looks great,drives fantastic (for me) and when you sort out any little bugs that these cars get they are hard to touch in the ol' fun factor department.
    Use your common sense when test driving...test drive as many as you can so you get a good feel for them and you can tell the difference in feel from a well maintained F-Body and a beat up put away wet car...
    Look for signs of collisions like paint that doesn't match very well,newer headlight on one side,misaligned body panels (although some misalignments are very common from the factory.Like Camaro tail light panels are off quite often).
    Front fenders tend to be popped out a little bit just behind the front tires.This comes from people who don't bother to look under the car before jacking and they end up bending the bottom mounting point of the fender causing the fender to bulge a bit.No biggie,just carefully straighten,problem solved.
    Not all these problems happen to everyone's cars,these have just been bugs that I have personally noticed over the course of owning 7 F-bodies over the years...Not to mention F-Bodies my brothers have owned as well...
    Anyways man...when you find your F-Body you will have a smile 10 miles wide brother...good luck!
    Jun 2009
    Columbia, SC
    2002 Monte Carlo SS
    Quote Originally Posted by Baluchitherium View Post
    for sure!!!!
    thanks for all the info guys, i really appreciate it!
    Senior Member
    Mar 2009
    Milwaukee
    Arctic White, red/gray
    1997 Corvette, 92 Typhoon
    Rear ends
    Bad window motors
    Dash Cracks
    The good side:
    What do you mean by hydraulic systems on the m6? Its a cable clutch
    It has a big wing!
    As far as I know all 4th gen V8 (which an SS would be) F-Bodies are hydraulic clutch set ups... Master,slave...etc...
    I have had to replace the master twice on my car and the slave once so...
    Only time I have ever dealt with a cable clutch set up on my car was with my old 92' Mustang GT..
    Senior Member
    Mar 2009
    Milwaukee
    You are right, i was thinking about when i pulled the tranny on the mustang
    Coral Springs, Fl
    Sunset Orange Metalic
    One thing i noticed was gaps between the front fenders and the doors towards the bottom. Some people jack the car up wrong and the bend out, or the body flexed it out of place. Besides that, all i can think of was already mentioned.
    Sep 2008
    Minnesota
    2001 Z28
    Not just on these cars but on any car before you start it turn the key to the on position when all the dash lights will come on, make sure that the CHECK ENGINE LIGHT ACTUALLY HAS A BULB IN THERE! I have seen people either get sick of looking at it or try to sell the car and just take the bulb out and 90% of people never even think the bulb might be taken out. But when you first start the car all the dash lights will come on for a second or two. So im sayin the car might have a small or large problem and you might not know at all because the check engine light will never come on at all. And Im sure someone will say if your car has a huge problem and you dont know without the light your a dumbass, but flood cars in particular are the thing that is popping into my mind right now.
    Jun 2009
    Columbia, SC
    2002 Monte Carlo SS
    Quote Originally Posted by MNZ28 View Post
    so would i be like, "hey is your check engine light bulb screwed in?"
    how would i know for sure without pissing off the owner?
    Sep 2008
    Minnesota
    2001 Z28
    just look at the light to see if its out when you cycle the key. you dont have to ask him anything. when you cycle the key all the dash lights will light up if the service engine soon does not light up then its either burnt out or not in there.
    Jun 2009
    Columbia, SC
    2002 Monte Carlo SS
    gotcha!
  1. '98 TA Ws6 - Possible buy, any areas for concern
    By SSwt00SS in forum Firebird / WS6
    Last Post: 01-25-2011, 08:55 PM
  2. Rear end concern
    By rapter34 in forum Drivetrain
    Last Post: 05-17-2008, 07:50 PM
  3. Idle concern
    By hawk18 in forum General Help
    Last Post: 04-08-2008, 01:23 PM
  4. To those it may concern
    By Blk00ws6 in forum Almost Anything Goes
    Last Post: 03-19-2008, 05:10 PM
  5. a slight concern
    By frankthetankjfpc in forum Manual Transmission
    Last Post: 01-18-2006, 12:04 PM
