Thread: Idle concern
    Feb 2008
    nicholasville,Ky
    2002 firehawk
    Idle concern
    any body have an idea why sometimes my hawk starts to idle to fast going through the gears clutch in sometimes shoots up to 2000 rpms. seems like the only way to stop it is to turn off the motor for a bit. and then it may not do it again for a few days..
    Bragg NC
    Met. Sunset Orange
    01 SS
    Try and clean you IAC valve/motor.
    J
    Feb 2008
    nicholasville,Ky
    2002 firehawk
    thanks , now if I can find out where thats at!
    I have a need for speed! jigger1166's Avatar
    Standish,Maine
    Artic White
    00 SS Vert.
    Quote Originally Posted by hawk18 View Post
    It could be the Idle Air Control valve sticking. It mounts to the throttle body.
    Any DTCs?
    Feb 2008
    nicholasville,Ky
    2002 firehawk
    thanks for the info. got it cleaned,and now for the test the next few days, it was pretty dirty ..
    SATX
    2000 Trans Am
    I would rather replace once it starts doing that its there till you switch it.
    Feb 2008
    nicholasville,Ky
    2002 firehawk
    idle concern fixed
    problem ended up being tps sensor. finally threw acode on the drag strip. thanks for the imput..
  1. '98 TA Ws6 - Possible buy, any areas for concern
    By SSwt00SS in forum Firebird / WS6
    Last Post: 01-25-2011, 08:55 PM
  2. Debris on MAF screen...cause for concern?
    By ls1fan74 in forum General Help
    Last Post: 05-03-2009, 07:06 AM
  3. Rear end concern
    By rapter34 in forum Drivetrain
    Last Post: 05-17-2008, 07:50 PM
  4. To those it may concern
    By Blk00ws6 in forum Almost Anything Goes
    Last Post: 03-19-2008, 05:10 PM
  5. a slight concern
    By frankthetankjfpc in forum Manual Transmission
    Last Post: 01-18-2006, 12:04 PM
