Results 1 to 3 of 3
06-15-2009, 06:07 PM #1
Emissions help...High hydrocarbons and High NOX
I need some real help.......I have 15 days to get my car to pass emissions. The car has brand new cats and currently has 3 gallons of methanol mixed in with the fuel.
Hydrocarbons (HC GPM) are reading 2.36 with a limit of 1.2
NOx GPM 3.13 with a limit of 1.5
My emissions are for Colorado.
PLEASE HELP......I am Stressing out
06-16-2009, 01:53 AM #2
You need to tell us about the modifications to your engine.
06-16-2009, 02:16 AM #3
sounds like your running strait alcohol.....it will settle to the bottom of the tank. the computer isn't setup to run flex fuel.
I'd run a tank or two of good 93 octane through it and try to pass again with no mix
Question: HIGH N0X readings on last emissions test?
By SuperSSguy in forum General HelpReplies: 5Last Post: 07-15-2012, 06:36 PM -
high volume / high pressure pump ?
By seweber in forum General HelpReplies: 4Last Post: 11-11-2011, 05:09 PM -
2012 Chevy Camaro ZL1 - High-Tech & High-Powered
By Ed Blown Vert in forum General Help - 5th GenReplies: 0Last Post: 06-29-2011, 02:00 PM -
high shift points & high idle
By Red 99 T/A in forum General HelpReplies: 5Last Post: 07-26-2010, 09:04 PM
