Results 1 to 2 of 2
    Go Vols! x10-wakerider's Avatar
    Memphis
    SLP Camaro SS
    Pinion / Carrier Bearing Install?
    While I am changing the outer bearings I thought I would change the other bearings as well. Are the Pinion and Differential Carrier bearings easy to change or should I leave them alone? I have a wahwah sound and I am trying to stop it!
    Madison, WI
    1999 Formula WS6 M6-sold
    2001 Silverado Z71
    You should at least look at them. If you see obvious damage then replace them. They have to be pressed on and off.
  1. Replies: 5
    Last Post: 05-19-2013, 11:14 AM
  2. question on pinion bearing race installation
    By jmr1 in forum Drivetrain
    Last Post: 08-07-2009, 12:01 PM
  3. pinion bearing costs?
    By zippa713 in forum Drivetrain
    Last Post: 03-12-2009, 01:12 PM
  4. wheel/pinion bearing?
    By mpowell04 in forum Drivetrain
    Last Post: 06-20-2008, 10:41 AM
  5. Rear end pinion seal / bearing
    By Blackout01 in forum Drivetrain
    Last Post: 08-08-2007, 11:49 AM
