Results 1 to 2 of 2
Thread: pinion bearing costs?
03-12-2009, 08:43 AM #1
- Mar 2009
- steelton
Im wondering how much it would cost to replace a pinion bearing in a 2000 z28 LS1 I THINK its a 12 bolt...
03-12-2009, 01:12 PM #2
It's going to be different anywhere you go. My shop would charge 3-4 hours labor @ $85 per hour plus the cost of gear lube, gear additive, inner and outer pinion bearing, pinion seal, diff cover seal, crush collar and possibly pinion shims if needed.
Noise from rear of the car? Axle pinion bearing maybe?
By Jknerr in forum General HelpReplies: 5Last Post: 05-19-2013, 11:14 AM -
question on pinion bearing race installation
By jmr1 in forum DrivetrainReplies: 4Last Post: 08-07-2009, 12:01 PM -
Question: Pinion / Carrier Bearing Install?
By x10-wakerider in forum DrivetrainReplies: 1Last Post: 06-12-2009, 06:18 PM -
wheel/pinion bearing?
By mpowell04 in forum DrivetrainReplies: 7Last Post: 06-20-2008, 10:41 AM -
Rear end pinion seal / bearing
By Blackout01 in forum DrivetrainReplies: 0Last Post: 08-08-2007, 11:49 AM
