01-30-2006, 04:43 PM #1
Wiring Conversion - This One is Tricky
I recently bought a few accent lights (LED) that I want to install over my subwoofers and amps in the trunk of my car but, they receive power through a car adapter (plugged in to a cigarette lighter) which are unfortunatly located in the front of the car as always. Is there any way you can think of to remove the car adapter from the setup and just connect the power/ground to nearby wires in the back of the car.
Here's the kicker... on the car adapter there is a button that you press to turn the light on and off. If possible I want to work that into this little fiasco as well. Is there possibly a pre-made converter for a situation such as this? Possibly at Radio Shack? They tend to have piles upon piles of things such as this I would think.
If you happen to have a solution to my quandry, don't get too technical. While I can make a geo metro go 0-60 in 4 seconds, I know little about electronics.
01-30-2006, 06:10 PM #2SUPREME member-oderator
- Nov 2005
- Lost in Texas
Custom Slate Blue- 99 B4C
They make external cigarette lighter jacks, buy one and wire it up in the rear, then plug er in
01-30-2006, 06:21 PM #3
You win.
Wow, so easy, I didn't even think of that.
Thanks a bunch.
01-30-2006, 06:40 PM #4SUPREME member-oderator
- Nov 2005
- Lost in Texas
where in texas are you
01-31-2006, 02:05 PM #5
Plano, it's a little north of Dallas, you?
01-31-2006, 05:52 PM #6SUPREME member-oderator
- Nov 2005
- Lost in Texas
Lubbock now, was amarillo back in my youth
02-01-2006, 09:20 AM #7Junior Member
I wired some UV LEDS under my seats, dash. I tapped into the the wire that has power when the headlights are on. Can't see the LEDS when it's light outside anyways. Now for the rear of the car, you could tap/splice into your stereo's 12v supply, or even the taillight (running lights) 12v supply. I would'nt want any cig. lighter socket stuff, myself. Make it hidden, make it automatic.
Just some food for thought.
Help: Firebird front end conversion headlight assembly wiring HELP
By augie1209 in forum General HelpReplies: 2Last Post: 01-06-2011, 06:46 PM -
Help: 94 formula front end conversion wiring help!! plzz
By augie1209 in forum Stereo and ElectronicsReplies: 4Last Post: 08-06-2010, 10:33 AM -
Tricky Idle Situation
By JattGunMan in forum General HelpReplies: 2Last Post: 04-16-2008, 06:03 PM -
How do i wire two seperate front tweeters with no factory wiring or wiring from deck?
By Mike Hawk in forum Stereo and ElectronicsReplies: 1Last Post: 11-16-2007, 09:41 AM -
Tricky VIN Number
By FuhBreezeE in forum Texas MembersReplies: 11Last Post: 07-06-2007, 07:46 AM
