Results 1 to 3 of 3
    Difficulty Shifting
    Today is about the worse it has been. But over the last month shifting into 3rd and 4th is gettting difficult. It won't shift as smoothly as it should. Sometimes I have to double shift in order to get into gear or grind it. Clutch has same resistance, no changes there. Car has 111 k miles and I know the clutch plates were change out at 70k. I am thinking it is the servos starting to going out. Any further input? Currently saving for LS7 Clutch Kit.
    Senior Member karpetcm's Avatar
    Tujunga, CA
    01 Camaro 6speed
    If its not shifting smooth then change the oil if you havent already but if its grinding then it could be a couple of things.
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    Since only 3rd and 4th are giving you issues, sounds like a transmission problem more than a clutch problem. Could be a few things, most common things are worn synchros/blockers or a bent 3/4 shift fork. If the fork is bent, it will cause engagement issues, and often causes the trans to pop out of gear.
  1. Heads difficulty
    By natews6 in forum Internal Engine
    Last Post: 05-29-2010, 07:54 PM
  2. Difficulty removing rear rotors
    By tremiles in forum General Help
    Last Post: 03-04-2010, 10:50 AM
  3. Shifting WOT into OD??
    By rick67 in forum Automatic Transmission
    Last Post: 09-29-2009, 06:11 PM
  4. 4L60E Rebuild Difficulty?
    By Finally in forum Drivetrain
    Last Post: 05-07-2008, 05:43 PM
  5. Difficulty Engaging Gears
    By qrunchi in forum Manual Transmission
    Last Post: 11-24-2006, 12:04 PM
