Results 1 to 3 of 3
Thread: Thumpr Cam
06-04-2009, 08:28 AM #1Junior Member
- May 2007
- Buffalo
Orange- 1999 Camaro
Thumpr Cam
For anyone interested:
I just finished the install of my new cam on my camaro (ls1 with an M6) and wanted to post my results. The cam I put in was the new thumpr cam by Comp Cams. It's specs are: 219/233 duration, .553/.536 lift on a 109 LSA. After getting the car back from being dyno tuned, the car is putting out 403 hp to the wheels and 390 ft/lbs of torque, while keeping the stock redline. My other mods are K&N air intake, 92mm FAST throttle body, FAST intake manifold, ported and gasket matched "stock" heads, long tube pacesetter headers, ORY pipe, magnaflow 3" exhaust, and 4.10 rear gear ratio. I have removed all of the emission sensors and replaced the springs, lifters, pushrods, timing set with comp cam recommended parts and did the throttle body coolant bypass mod (every horsepower counts!). The idle has a choppy thump, nothing overwhelming but definitely makes enough noise at a red light. I have the horsepower and torque curve, but can't figure out how to paste it to this post.
06-04-2009, 09:48 AM #2Junior Member
- Dec 2007
- Austin, TX
Pewter- 2002 Trans am WS6 T-top
lsa
Just for clearification; the lobe seperation is 109. Thats not the center line? Did the kit come complete with the springs/lockes/retainers?
06-04-2009, 10:29 AM #3Junior Member
- May 2007
- Buffalo
Orange- 1999 Camaro
The 109 is the lobe-center angle. I bought the springs, lifters and pushrods seperate. Comp cams did not offer a k-kit for this cam.
Question: Thumpr cam is in!
By fmkidd in forum Internal EngineReplies: 17Last Post: 11-03-2012, 10:15 AM -
Question: Which Muthra Thumpr Comp Cam to use in LS1
By cballweg in forum Internal EngineReplies: 8Last Post: 08-24-2011, 06:36 PM -
Help: LS1 Muthra Thumpr comp cam -anyone have this cam?
By cballweg in forum Internal EngineReplies: 0Last Post: 08-22-2011, 03:28 PM -
Question: thumpr 291 vs. t-rex cam????
By Steve's LS1 in forum Internal EngineReplies: 8Last Post: 03-02-2011, 04:23 PM -
Question: Anyone using Comp's Mutha Thumpr?
By ne0fiend in forum CorvetteReplies: 1Last Post: 06-25-2010, 11:17 AM
